It's not frozen over and the fan outside is blowing...
SOURCE: My air conditioner runs outside, but there is no
If your Indoor Coil is Froze Up, you need to shut the unit off and let it thaw out. After it thaws out for several hours, then turn the blower on at the thermostat, you’ll see a switch that says fan on/ auto
Move the switch to on and see if the blower runs if it does let it run another hour or so. Then shut it off and check your filter and indoor coil to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant. If the blower doesn’t run when you turn the switch to on then you need to check the blower out,
If your not familiar with any of this then you need to call a service tech.
SOURCE: AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician. The freezing up usually is associated with a low refrigerant charge or low air flow. Check your return air filter and replace as needed.
SOURCE: My Trane air conditioner is not blowing cold air
there could be a few things low on freon will cause the coil to ice up and no air can get through,breaker or switch to the blower unit in the house is off belt broke or the moter let go
