20 Most Recent
Goodman PHKJ060-1 Air Conditioner Questions & Answers
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF.
IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
1/5/2022 2:44:45 AM •
Goodman...
Answered
on Jan 05, 2022
No air fan is blowing
MAKE SURE THERMOSTAT IS SET TO AUTO AND COOL OR AUTO AND HEAT...IF SWITCHES ARE SET TO ON AND OFF ONLY THE
FAN WILL RUN....IF YOU CAN'T FEEL ANY AIR HOT OR COLD THEN
YOU HAVE A VERY DIRTY INDOOR COIL OR FILTER OR BLOCKAGE IN THE PLENUM OR BROKEN OR DISCONNECTED DUCT WORK...IF YOU FEEL AIR AND IT IS NOT COLD YOU MAY NEED A FREON CHARGE TO YOUR UNIT. ALSO CHECK ALL BREAKERS AND CHECK INSIDE AND OUT FOR DISCONNECTED WIRES , SHORTS , GROUNDS , FUSES , AND MAKE SURE THERMOSTAT WIRES ARE CONNECTED TO THE PROPER TERMINALS. IF THEY ARE NOT THEN CONNECT THEM TO THE PROPER TERMINALS. REMEMBER..LOOK FOR THE SIMPLEST THINGS 1ST.
4/13/2010 9:49:03 PM •
Goodman...
Answered
on Apr 13, 2010
Goodman gas furnace model number gms80904bna won't light. Changed the flame sensor and the ignitor is bright orange please help
Obvious that the unit isn't getting gas to the ignitor.
To receive gas to the ignitor, there is a gas valve located upstream of the burners.
Have a friend turn on the heat while you are up close to the furnace.
Once the ignitor gets hot, there will be an audible "click" at the gas valve when the low voltage controls call for the gas valve to open to supply gas to the burners.
Listen for it.
If you hear a click, and the furnace still isn't firing, you need to check to see if someone has closed the gas shut off supply valves located on the gas line.
If all the shut off valves are open, you need to verify you have gas pressure in front of the gas regulator.
If you verify have pressure on the upstream side of the regulator, you will need to verify there is also pressure downstream of the regulator.
If there is gas pressure upstream but none downstream, replace the regulator.
If you have pressure downstream of the regulator, and the gas valve clicks, but furnace doesn't light, replace the gas valve.
LP has higher pressure than natural gas, and is dangerous.
LP is heavier than air and will sink to the floor or lowest area.
One static electricity spark is all it takes and an explosion can occur.
