These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
If you wish to get more about the blinking codes to Panasonic FPTvs, try the site linked here. It has details to blinking codes to many model Panasonic TVs. Pull up older posts.
Have you counted the number of blinks that occur at one time switch ON? If not, count it. http://electronicshelponline.blogspot.com/ Check this link for more details about the blinking codes. It has blinking codes to several other brands of TVs including many Panasonic models. Pull
up older posts there, either by its left side bar, or see it in Timslide
option.
How many times do the standby light blinks at one time switch ON? Count it. These blinks are called blinking codes and are fault indications. Form these number of blinks, you can get an idea about the faulty circuit section inside the TV. If you're sound in electronics, you can do it by yourself. If you wish to get more details http://electronicshelponline.blogspot.com/ about the blinking codes to Panasonic Brand Tvs, check the link. Pull up older posts there by its left side bar. Blinking codes to many brand TVs are give in detail.
