20 Most Recent Panasonic PT-50LC13 50" Rear Projection HDTV Questions & Answers
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Panasonic... | Answered on Jun 07, 2019
Not aware of any cooling fan in a TV system
Panasonic... | Answered on Nov 04, 2017
That appears to be a power supply on its ***** throes. You might want to shop around for a new PS
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sears Online In Store Shopping Appliances Clothing More
Panasonic... | Answered on Sep 20, 2017
You have a shorted circuit board inside the TV, have it repaired.
Panasonic... | Answered on Jul 06, 2017
sounds like the lamp faceplate is not screwed back in properly
Panasonic... | Answered on Dec 11, 2016
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Panasonic... | Answered on Jun 03, 2016
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Panasonic... | Answered on Sep 15, 2015
Hello, the optical block or light engine which ever you want to call it has gone bad, it's a very common and expensive repair to which I do not recommend doing. I would put the money into a new set. I'm sorry for the bad news.....tks
Panasonic... | Answered on Sep 15, 2014
It is in the front on the left of the bulb compartment. It is as easy as removing two screws using lots of DAMP Q tips and having some patience. Keep carefully swabbing top and underside filter until clean, then lightly and very carefully vacuum with a home vac do not use a shop vac!
Leave TV unplugged with cover off as long as you can I would say a few hours or overnight and then plug in. If the filter is clean and you still get the error message there are other posts here that explain how to go into service mode and reset.
You do not need to spend hundreds of dollars on a "Panasonic" technician who has "done it before". You can dooooo it!!
Panasonic... | Answered on Jul 22, 2014
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
482 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
worth fixing panasonic pt 50lc13 k rear
  • Televison & Video
