Washing Machines Logo
m
michael beer Posted on Mar 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i press the power button on my washing machine it powers up and all the light come on. then when i go too choose the wash cycle nothing happens. does anyone know what may be the cause?.
When i press the button to select the wash cycle it clicks like its working but does nothing.
Jorgie the appliance guy
Level 3:
Top Expert:
  • Washing Mach... Master 5,639 Answers
  • Posted on Mar 09, 2015
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523848
Points
32630
Check for blown fuse in panel but more likely a bad door switch
Reset on a Kenmore whirlpool
Press the stop button twice times and then press the power button after that choose wash cycle also choose wash options after that press the start button to complete the reset button
I have a Bosch SHU9902UC/U06 Dishwasher that won't start.
No water getting in check water inlet pipe is not twisted or turned off eric992
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
I own a wcvh6600hww front loading easing machine. I load the clothes, soap, etc...go to start the load. Hit power , choose my cycle, & then I try to press start, but nothing happens...the start/pause...
It sounds like it's gamed, the fact the button is flashing shows a major problem, turn off power, remove the motor still connected, if it runs o.k.the problem is the machinery, or vicer /verser, if it is jammed machinery take various parts off until things move.
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
2answers
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
My frigidaire will not go through any cycles>
It may have defaulted to 8 hour delay, ours did after a storm and the power went off, see if the 8 hour delay button is lit, if so press to return to instant wash.... hope this helps
2answers
No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Top Washing Machines Experts
john h
