Cars & Trucks Logo
A
Anonymous Posted on Mar 05, 2015
I need instruction/installation manual for Arlec door chime
handymanloui
Level 2:
Sergeant:
  • Expert 210 Answers
  • Posted on Mar 05, 2015
handymanloui
Expert
Level 2:
Sergeant:
Answers
210
Questions
0
Helped
49764
Points
696
2002 Lexus sc430 location of door chime
most cars IT is deep in the IP cluster
only the SM service manual shows this.
door AJAR CHIME
THE DOOR OPENS AND DOOR CPU SENDS THIS
DATA FACT TO THE CLUSTER, (ON THE MX DATA NETWORK AND THE CLUSTER CHIMES.
if the chime is bad say so? we can not guess goals.
or too loud or what?
here it is
2005 Dodge grand Caravan door chimes continue with key out,
Wiring, schematic, electrical diagrams, torq settings, parts info, error/fault codes, full assembly/dissembly, service instructions and a lot moreetc are basic contents of these online books they here on this website https://big-manuals.com/products/dodge-caravan-2001-2007-workshop-service-repair-manual
How is door sensor wired up as red and black wires are tied together
I think you could
use this manual method instead.. My nephew who is a full time mechanic uses most of the times, and all mechanics look up to manuals. It's very easy Here's the website he bought it from. www.reliable-store.com
Back doors locked shut. how do i open them.central locking innoperative
Use the key fob to open the rear doors by pressing the unlock function twice. If you need reprogramming instructions, use the following:
2002 Focus
  1. Turn the ignition from OFF to RUN 4 times within 6 seconds.
  2. Turn the ignition OFF. The system will chime to confirm programming mode.
  3. Within 20 seconds, press any button on first keyless remote. The system will chime once to confirm programming.
  4. Within 20 seconds, press any button on second keyless remote. System will chime once to confirm programming.
  5. Turn ignition to RUN to exit programming mode.
Wiring diagram friedland door chimes
These are installation and wiring instructions for the Friedland 954 Door chime.
wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-0.jpg wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-2.jpg wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-5.jpg wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-9.jpg
Courtesy Chime Chime Chime will not shut off. What do I have to do to troubleshoot the GEM Module and whatever is connected to/through it?
If the chime includes the cab light staying on as well:
There is a door switch in both the driver and passenger side doors that needs attention. I too had this problem. Solution: squirt wd40 onto the switch located near the door latch on both driver and passenger side.
2answers
TRYING TO FIX A DOOR CHIME ON A 2002 PONTIAC SUNFIRE. NEED TO LOCATE WHERE DOOR CHIME IS LOCATED ON THIS VEHICLE
In most vehicles the "chime" is located in the dash around where your 4 way flaser is. It could simply be the door switch also which is a little button that depresses when you close the door to open the circuit shutting the dome light and chime off. They are easy to change and inexpensive. Hope that helps.
2helpful
Need programming instructions for RKE for 2000 Mazda 626
2000 Mazda 626
Note: Make SURE the battery is new.
Instructions for programming ONE keyless remote fob.
1. Open the driver’s door & leave open.
2. Insert the key in the ignition.
3. Turn the key to the on and off position 3 times.
4. Remove the key from the ignition.
5. After door open chime stops, press the door open button 3 times.
6. After chime, press any fob key twice.
7. After second chime, press any fob key twice again.
8. After third chime, press any fob key twice again.
9. Press the door open button once.
10. The car should give another acknowledgement chime.
11. Test key fob.
This DOES work. I just programmed mine successfully today, three hours ago.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
