A
Anonymous Posted on Mar 04, 2015
How do i change time on my lenovo tab to pacific time
My tab is set to eastern time . I want to change it to pacific time zone
William Alequin
Level 3:
  • Master 932 Answers
  • Posted on Mar 04, 2015
William Alequin
Master
Level 3:
Answers
932
Questions
0
Helped
201810
Points
2855
Go to settings, Time and Date, make sure that the time zone is not gray out, if it is, disable automatic time zone, scroll down to the time zone and change it to Pacific, which is GMT -08:00
My atomic clock shows pacific time, but we are in an Eastern time zone. T
Clock should have the ability for you to change setting to Eastern zone
tip
Procedure For Setting Time Zones For Emerson Clock Radios
Setting The Time, The First Time
IMPORTANT: The first time you connect your new SmartSet® clock radio to
the AC outlet the internal computer will automatically set the time correctly for
the Eastern Time Zone, which is the initial default setting. The display will
scan for a few seconds and then show the correct Day and Time in the Eastern
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
clock is set correctly and running.
If you do not live in the Eastern Time zone you must change the default zone
display to your own zone. You only do this one time and the SmartSet® will remember
the new default zone setting and will always return to that setting after a power
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
indicating that the default zone is ZONE 2,
Eastern Time
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
17helpful
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
3helpful
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
67helpful
3answers
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 • Watches
12helpful
Can not change the Brookstone Projector clock from Pacific time. We live in eastern time zone. where do I get a manual
Choosing a time zone. To select Pacific, Eastern, Mountain or Central time zone, press ZONE button inside battery compartment of clock unit.
2helpful
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Why won't it automatically set time?
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
 Grubhead
Grubhead
SmartAviator
SmartAviator
