Cars & Trucks Logo
A
Anonymous Posted on Mar 01, 2015
Rear drivers side seat is stuck down on my Mercedes 2004 ml350, how can I get it to release and come up
Put seat down and it stuck in that position...lever does nothing
tschulte8
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Mercedes-Benz Expert 92 Answers
  • Posted on Mar 03, 2015
tschulte8
Level 2:
New Friend:
Cheetah:
Answers
92
Questions
Helped
36903
Points
131
There is a cable that runs from outer handle on the seat and connects to a rotating tube/latch at the inner seat frame. you will need to use a long flat scew driver from behind that part of he seat to slip in theat latch and twist to unlatch that seat then you canr repair the cable.
Aux battery location in 2009 ML350 Mercedes?
It is located under the passenger seat. May have to loosen the pass front seat mounting screws and remove the two rear screws and lift the seat up at the rear about 3 inches to replace it.
https://www.youtube.com/watch?v=o7hfpkJrfLo
https://www.ebay.com/itm/Mercedes-W164-W251-GL-ML-R-Class-NEW-GENUINE-Auxiliary-Battery-1-2AH-/112041275311?_trksid=p2349526.m4383.l4275.c10
000000 004039 Genuine OEM...... Other Part Numbers: 82533004001 / 825 33004 001 / 000000 004039
The rear drivers side passenger seat in my Mercedes 2004 ml350 is stuck down...how do get it to come back up. very little room to work
Not an easy task. You likely have one of 2 problems. If center seat belt is in the seat that is down, it may be locked. If so, you need to remove the seat back cover then the seat belt retractor. You can then position the seat belt retractor upright (how it sits when the seat is up) and pull the seat belt out making slack to raise the seat. This only happens if the either the stop on the seat belt is broken or the seat belt guide on the seat back is broken. If that's not the problem, you likely have a release cable that has come loose under the seat. If you look at the half that works, you can determine what you need to move on the locked seat and try to get to it with a long tin screwdriver or similar implement.
3helpful
3answers
Can you fold down rear seat on 2007 chevy malibu
To fold-down rear seat on 2007 Chevy Malibu, follow these steps:
1. Open the trunk
2. Pull on one or both the handles located on the upper side of the trunk
3. The handle located on the driver's side will unlatch the bigger part of the read seat
4. The handle on the passenger side will fold down the smaller portion of the rear seat.
5. Once done, you will have a seat that's nicely folded down.
My 06 malibu rear seat will not go down due to stuck switch
Push on the seat to the rear while pulling the cable release. Sounds like latch is adjusted too tight. If this works make adjustment before putting the seat back up. Open trunk & you should also be able to get to the speakers and the latch for the seat back. May require a screwdriver or something narrow & long to push on the latch arm while another person pushes & pulls the seat back to unlatch.
Chris
ASE Master Certified sense 1979
How do I life the rear seat to fold down the back of the seat?
will need to try and see if latch is damaged or debris is jammed in latch with the other side up look under at latch also check the cable --you can try kneeling on seat and bounce and pull on tab to try and get it to release
How do you install a driver seat plastic shield on a 2004 Ford Explorer? Its the piece of hard plastic between the door and the seat - part number 1L2Z-7862187-BAC
see if this helps
  1. Remove the rear trim screw.
  1. Remove the lower trim screw.
  1. Release the side trim front retaining clip.
  2. Pull the lumbar mechanism out slightly from the seat.
  3. Push down and pull out, releasing the side trim front retaining clip.
  4. CAUTION: Take care when removing the side trim cover. Excessive force will break the mounting tabs.
Release the side trim from the mounting bracket.
  1. Disconnect the seat control switch electrical connector.
2answers
3rd Row Seat Stuck
the release cable has broke ,take the seat out and have a play to work out whats wrong ,you may be able to repair it with a bicycle brake cable
Rear Seat on C Class coupe will not release think I ned to take the seat backing off to look at the mechanism
i beleive the release handles are in the trunk. Unless the release handle broke or cable is broken it is probably out of adjustment. Try having someone lean into the seat backrest and then pull release handle. I'm assuming your talking about your backrest release. If you are refering to the seat cushion-they can be tough but try putting some weight down on the cushion and then try pulling the release handle at each side of the seat.
1helpful
2004 Saturn Vue - Getting Rear Seats Back To Upright Position
Push down on the seat then pull the handle or both at the same time then pull up while holding the release up, it got me at first, but thats how i got it
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
