Does it trip on other programmed cycles? Or, do you only have the one circulation time? This one is odd, if it only trips during one of multiple cycles. It could happen this way: if you have two or more cycles programmed, and only the one 6:00 cycle has the option for the heater to come on, then you could have a bad heater element? But the situation would have to have the spa in economy mode. Because heater will work only when timed filter cycles are activated, and if a demand for heat is registered, the heater will come on,and in your case, breaker will trip. If in standard mode, the breaker will trip any time the spa comes on, when a demand for heat is registered, this is called "heat call" or call for heat. Good luck
