20 Most Recent Intex Automatic Salt Water System for Above Ground Saltwater Pool Questions & Answers
3answers
How do you clean plates on intex saltwater
Remove the salt cell housing and plug one end. Pour cell cleaning solution into the housing until the cell is covered. The cell is clean when no further bubbles are formed and you can see shiny metal cell plates.Remove the cleaning solution flush the cell with clean water and install the salt cell housing back into the system.
1/23/2024 6:33:45 PM • Intex Automatic... • Answered on Jan 23, 2024
2answers
My salt water pump keeps
I suggest you clean the cell according to manual and try it then. If it keeps producing chlorine then keep swimming. If the pump is flowing water fully (if not clean baskets and filter) and it can't keep the chlorine above 2 ppm and you have 30 to 50 ppm stabilizer in the water then there is a major problem in the chlorinator. I don't trust the salt indicator on some chlorinators but that is less important than if it chlorinates. You can but salt test strips. I hope this helps.
11/15/2022 5:53:42 AM • Intex Automatic... • Answered on Nov 15, 2022
3answers
How do i clean the salt water pump
Remove the salt cell housing and plug one end. Pour cell cleaning solution into the housing until the cell is covered. The cell is clean when no further bubbles are formed and you can see shiny metal cell plates. Remove the cleaning solution flush the cell with clean water and install the salt cell housing back into the system.
9/22/2022 4:06:47 PM • Intex Automatic... • Answered on Sep 22, 2022
0answers
2answers
What is a code 93?
Code 93 = Good News for You! :-D It is your Saltwater Chlorinator's way of letting you know that it is working properly and your pool's water has a level of salt that is optimal/good.
Code 93 just lets you know it is not actively converting salt to chlorine...it is in 'standby mode.' When you first programmed the number of hours you wanted it to run (by pressing the left (down)arrow until you heard the beep, then pressing the right (up) arrow until you heard the beep - then pressing up until you reached the desired number of hours you wanted the unit to operate (minimum 1 hour, maximum 12 hours)) the unit began converting salt to chlorine immediately.
This is good news for you. Once the number of hours of operation are up, your unit will give you a code when you press either button. If your salt level is too low, you will receive code 91 indicating this, if your salt level is too high, you will receive code 92 indicating this, if the water flow is too low, you will receive code 90 indicating this (this gives you the opportunity to correct this before the next cycle begins. If there is no error with your pool's water, your unit will go into standby and wait until it is time to run the numbers of hours you programmed it for (it will begin it's cycle at the same time each day unless reprogrammed by you). When this happens, you will find code 93.
So, just to recap:
Code 93 = Good
Code 92= Salt level too HIGH (Empty approx. 20% of pools water & refill with fresh water.)
Code 91 = Salt level too LOW (Add salt.)
Code 90 = Low Water Flow (Check your filter. If it is working properly, you may find that it is too small for your pool. The filter that came with my pool was FAR TOO SMALL - I spent more time cleaning the pool than swimming in it. My 18' x 4' pool came with a 1500 filter. Now, I have a 4000 Sand Filter. This + the Saltwater Chlorinator = practically no maintenance. Together, these were approximately a $500 investment. WELL WORTH IT!!!)
Code 88 = Startup mode. (Press down arrow until you hear the beep. Press up arrow until you hear the beep. Press up arrow until you have the unit set to operate the number of hours you desire.)
As an extra FYI: The unit works with the sun. This means the unit turns the salt from your pool into natural chlorine which is then sent back into your pool. The sun turns this natural chlorine into salt. Your filter sends this salt into your saltwater chlorinator where it is again converted into natural chlorine & returned to your pool where then sun...I think you get it. ;-) It's a continuous process. ~This being the case, when you program your saltwater chlorinator, it is best to set it up to help it work with the sun rather than setting it up to compete with the sun. You do this by programming it to run at night. This way, your unit isn't working hard to generate chlorine at the same time the sun is diligently converting the chlorine to salt. I've read several articles where people argue that you should run your saltwater system at night & your filter during the day. I don't understand this concept. My filter runs 24/7 & my saltwater chlorinator runs 12 hours - from 8pm to 8am. Since I set my pool up to operate this way, I have not had to clean it at all other than backwashing the filter every other month just for principle. My water is crystal clear.
One further note of interest: My pool holds approximately 6000 gallons of water. For this, Intex recommends 135 pounds of salt. Because of some advice I'd read posted by other users, I started with only one 40lb bag. This was all my pool needed. Approximately once/year, I add one more 40lb bag.
RJBALLZER777, because you are receiving code 93, I realize you have set your pool up correctly and, therefore, are possibly thinking, "Why is she telling me all of these things I don't need to know?" I apologize if that is what you are thinking. I am really posting for those who have not gotten it just right the first time (or who are doing their research before buying as I did) so that they may get several questions answered at once. Hope you don't mind that I used your question as a means to post. (That's why I answered your question right off the bat.) Hope this post helps some.
2/6/2022 6:34:01 PM • Intex Automatic... • Answered on Feb 06, 2022
5answers
I keep getting code 90 (low water flow) on my
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
7/16/2021 11:01:41 PM • Intex Automatic... • Answered on Jul 16, 2021
2answers
Having water flow ,allways says low flow and just changed sand last year
changing sand was a good start. make sure to backwash the system to keep sand clean. backwash until the waste water is clear. if this is not the problem, check the system for a blockage. you would be amazed how many times i remove a golf ball or foam toy from systems
7/12/2021 6:18:19 PM • Intex Automatic... • Answered on Jul 12, 2021
2answers
Bought saltwater system last year
Keep in mind, as soon as the system detects low flow, it turns the electrolytic cells off to prevent from burning them up.. If you have good flow and still get this alarm, check the flow sensor for dirty, stuck, defective or broken. See picture below..
7/12/2021 6:17:51 PM • Intex Automatic... • Answered on Jul 12, 2021
2answers
Help brown pool water, high iron content in well
your alkalinity is way too high. It shouldn't be above 7.8... 7.4 - 7.6 is ideal. I use muriatic acid to lower my ph. Also, your alkalinity is too high. should be between 80 and 120.There is a sequestering agent you can use to try and drop the metals out of the water, if any are present. You stated you had high iron. However, before tackling the iron, you need to get your ph under control. Chances are if you get your ph and alkalinity in line, your water will look a whole lot better. If it is still cloudy, I would use a floc product.
7/12/2021 6:10:37 PM • Intex Automatic... • Answered on Jul 12, 2021
5answers
I have a sand filter and my levels say ideal but water is real cloudy after adding chlorine
Take a sample to a pool shop and find out. If the pool has been green you may have dead algae floating around, a sand filter will never take that out. You need to flock it or new water. Then there is the toy you call a sand filter, OK when everything is perfect but small filters and pumps just won't handle a very dirty pool.
7/12/2021 6:03:02 PM • Intex Automatic... • Answered on Jul 12, 2021
My intex saltwater system green light then low
You need to add salt to the water. How much depends on what size pool you have. Your owner's manual will tell you exactly how much to add when the low salt light comes on. On my Intex I would need to add 35 lbs.
7/1/2021 9:47:09 PM • Intex Automatic... • Answered on Jul 01, 2021
3answers
Hi i have a 18 x 48 above ground intex frame pool
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
6/14/2021 2:29:36 PM • Intex Automatic... • Answered on Jun 14, 2021
2answers
I have saltwater sytem 8110. i have no chlorine level 7.2 ph very high alkalinity no copper. low salt light have added 20 lbs of salt. water clear tastes salty. what do ineed to do
I am having the same problem I wonder how to tell if my salt water system is working. My ph is good but I still have no chlorine or copper
6/12/2020 4:04:24 PM • Intex Automatic... • Answered on Jun 12, 2020
I have an Model 8111
It might mean you need to clean out the filter or the chlorinator cell. I hope this helps.
5/31/2020 1:52:09 AM • Intex Automatic... • Answered on May 31, 2020
Just plugged in intex 8111 saltwater system and it ran for about 30 mins and stopped, why?
What does the yellow light mean on my 8111
5/31/2020 1:27:52 AM • Intex Automatic... • Answered on May 31, 2020
I am getting a error
I installed a new Intex ECO 8110 unit on my 15' above ground, steel sided pool. After about 10 hours of use I had the "code 92' high salt alert that shut the system down. I knew that my salinity wasn't high because the local Pinch A Penny pool store does free water analysis and i was given the okay just a week prior. We had also received a bit of rain in the interim so I knew that the alert was false. Here is how I fixed the problem (so far). 1. Turn your unit off. 2. Disconnect the power cord from the outlet and wait for 2 minutes. 3. Unscrew the retaining nut at the electro-cell connector and unplug the connection. 4. Rotate the plug 180 degrees to reverse the polarity of the plug and re-connect to the electro-cell. 5. Reconnect the power cord to your receptacle. 6. Turn the unit on, wait for the green light to burn steady. 7. Monitor for the next 5-10 minutes. My unit has worked flawlessly for 3 hours. If i receive another "code 92" alert i will repeat the procedure which will result in bringing the unit back to its original polarity.
7/6/2019 8:14:01 PM • Intex Automatic... • Answered on Jul 06, 2019
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
5/2/2019 1:42:58 PM • Intex Automatic... • Answered on May 02, 2019
Intex pure spa led display is reading all 8s and every indicator lights are on but nothing works this is the pure spa model number ssp-10-1 & ssp-h-10
Sorry to hear that you have been the victim of a common plague associated with the inter spa. if your unit is no longer in warranty then you will have to buy the new head. The head being the part held in place by the three hex socket screws. Remove the screws, lift the head and unplug the harness, when the new one arrives just install in reverse order. this happened to me and my replacement head is still going strong three years later. look up intel parts on the internet and find the part you need and order direct. my replacement head cost $34 then.
10/24/2018 3:09:43 PM • Intex Automatic... • Answered on Oct 24, 2018
I have a 15foot round
first balance the pH and then test other chemicals BALANCE pH FIRST. and rum pump continuously for a few days. and then about 8 hrs a day. Jay the pool pump repair guy in longwood Florida.
3/8/2018 7:08:56 PM • Intex Automatic... • Answered on Mar 08, 2018
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,299 questions posted
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
am getting error
  • Pool & Spa
