20 Most Recent
Intex 2100 Gph 95 Hp Sand Filter Pump With Gfci () Questions & Answers
I bought the Intex 2100
these pumps should run 24/7 as they are SMALL,
try contacting Amazon. see if you can get a replacement pump, pump only. also, see my tips and tricks keeping pool from turning green
Loosing pump suction when vacuum pool
keep out all the air inside the lines. When Pumps loose power suction is because there is some air inside the lines.exaust the air inside the lines
Need to put sand filter
Drain the water from the filter and pump housing. With the water out of the filter, you can now shore the filter near the pool or in your near by shed or garage.
My system has cracked two
- Too much pump for the filter
- Clogged filter / dirty filter restricting flow and building pressure
- Hose(s) too small a diameter
- Restrictions in or blackage of a return line
- Hoses connected to skimmer/inlet and return in reverse or incorrect order
- Problems with the filter valve not routing water correctly
- Bad pressure gauge misleading you on overall system pressure, again, clogged filter being the real issue
If it is none of those look at water chemistry being way off stressing the plastics or pool users climbing on the pump.
John
