Sony STR-DE597 Receiver Logo
A
Anonymous Posted on Feb 15, 2015
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
Nothing yet,I want to know if Ican hook the subwoofer into my Sony receiver and how? Thsnks
Mike Smith
Level 2:
Scholar:
New Friend:
  • Expert 65 Answers
  • Posted on Feb 18, 2015
Mike Smith
Expert
Level 2:
Scholar:
New Friend:
Answers
65
Questions
0
Helped
34523
Points
356
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
5 Related Answers
yeroc
Custom Exchange
  • 397 Answers
  • Posted on Jan 20, 2008
SOURCE: no sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Anonymous
  • 1512 Answers
  • Posted on Mar 18, 2008
SOURCE: sony str-de-545 a/v receiver
Just answered that question for you in another post, but here it is again in case you miss it.
Hi there, Is the socket actually broken, or is it just playing up. It may just need some dry solder joints reflowed to fix it. If you are lucky, this may be done without a full strip down.
If you need to replace it, you will have to pull the board out of the unit, or at least the back panel completely off to get access to the soldering of the socket to replace it. This is not a difficult job, but often requires almost complete disassembly of the amp to do so. Time consuming...yes. It is something that unless you have some confidence at dismantling and reassembly gear, I would suggest that you refer it to a repair man. Good luck, I am happy to answer any more questions you may have.
regards
Graeme
Anonymous
  • 8546 Answers
  • Posted on Feb 07, 2010
SOURCE: Can I connect a active subwoofer to my SONY
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Anonymous
  • 8546 Answers
  • Posted on Apr 10, 2010
SOURCE: HELLO HOW TO CONNECT SUBWOOFER TO SONY
It would depend a lot on what type of subwoofer you have and it wouldn't be pretty.
According to the manual I found it doesn't have a Woofer Output so it isn't designed to route Low Frequencies anywhere.
Even if you rigged an Active Subwoofer to it using the Tape Output you wouldn't have central volume control for it unless the (unnamed) Sub was driven by speaker-level outputs from the Front A or B Speaker posts on the receiver.
Your question would be better framed and answered if we knew the details of the Sub and referred to ITS manual.
Testimonial: "Thank you for your advice. This is exactly what I needed to know . Jerry"
Anonymous
  • 8546 Answers
  • Posted on Jan 21, 2011
SOURCE: Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
2answers
I have the sony str-de1075 reciever.i want to hook up a sub-woofer.but it only has 2 single port.not your reg.rca ports.what do i do..thanks..
Sorry but it's not clear enough what kind of subwoofer (passive or active) you want to use. The passive one has no power supply connection, the active one has a power supply connector and the audio connector can be connected at the "audio out" for the subwoofer, at the rear panel of your STR-DE1075. Take a look at this photo:
In case you need a user manual for your receiver, here is an official link.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
No sound when hooking receiver to subwoofer using standard red RCA cable. Do I need a subwoofer cable?? I have turned my tuner subwoofer to YES, powered up receiver and subwoofer but nothing.
Probably not if it takes RCA input, but the receiver needs to be informed of the sub's presence and hw you want to share low frequencies among the rest of the speakers and itself. Then you need to set the relative levels using test tones, which also proves the sub works.
http://www.retrevo.com/support/Sony-STR-DH700-Receivers-manual/id/23341dj691/t/2/
Page 102
Set the subwoofer to YES (Page 43)
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Sony str-de97 fm/am receiver
you need to change the audio amplifier iC´s damaged
1helpful
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
My subwoofer and surround speakers don't work. However the main speakers work.
sony... its in stereo mode. hit the movies, music or afd buttons for the receiver
Need a remote for for Sony STR-DE597 Receiver.
Bad news, most every universal remote is for tv, vcr, dvd, cable box, and nothing else. you can goto sony.com or check ebay for a new one.
2answers
How do i hook up my ipod to a sony STR-DE597 6.1 channel reciever?
have u checked the COMPATIBILITY of the IPOD with your system(receiver/amplifier). the software of some models is not compatible withyour respective receivers.
Go to their sites for software upgrades.bye.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
