Bulova 96L37 ladies watch
1. Take the watch off your wrist and turn the watch so that the back of the watch is facing up.
2. Use a watch case opener or a small flathead screwdriver to remove the back of the watch.
3. Carefully take out the old battery and discard it properly.
4. Insert the new battery, making sure the plus and minus signs line up with the corresponding symbols in the watch.
5. Securely close the back of the watch.
6. Put the watch back on your wrist and you're done.
SOURCE: my bulova watch isn't working
Even you change a new battery with desame size and volts not working.The problem is in the terminal where going to put the battery.The terminal had a dirt or a film residue that comes out from the battery,you better clean terminal by scratching the old film,the lying down terminal is negative,,the side terminal is positive you better observed polarity if happen inter change the battery side it will not works.If not working, even you clean already terminal,short the terminal connection for 3 seconds,If you have a flourescent with a ballast,put your watch lying where there is strong vibration for five minutes, your watch works 100% txt me whatever the result so i know it's ok.
SOURCE: i need to add 2
Contact Bulova for additional links, 800-233-3350. You will need the watch model number and the case number (it's in the back beginning with "C".
SOURCE: bulova 96R19 ladies diamond chronograph
Watch shops use a press to put backs on. Some will snap on using your thumbs, other need the press to apply more force.
SOURCE: I have a bulova 98m36 ladies watch and I need to
I advise you to take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
This is particularly true if you watch is sealed as replacing the back can be difficult.
SOURCE: just replaced the battery on
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
