20 Most Recent Bulova Men's Watch Questions & Answers
4answers
I cannot get the back of my Bulova watch back on.
Most Bulova Watches have PRESSURE TIGHT backs. Meaning the back is applied with EQUAL amounts of pressure to the entire back. There are two(2) solutions:
1. Take the Bulova watch to an experienced watch dealer/repaiman, to have the back applied, or
2. CAREFULLY MAKE SURE THE BACK IS IN THE PROPER POSITION, then WRAP THE ENTIRE watch with a soft, cushy clothe and with a pair of pliers, CAREFULLY apply pressure to the center of the back plate, until the back covers seats to the proper depth(closed), at the same time BEING VERY CAREFUL not to crack the watch crystal!!
6/14/2021 2:31:22 PM • Bulova Men's... • Answered on Jun 14, 2021
Watch is Beeping loudly on every hour!
While pushing and holding the RESET button in, press the START button to toggle between CHIME ON/OFF.
3/1/2020 5:50:28 AM • Bulova Men's... • Answered on Mar 01, 2020
4answers
Military Time
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
Chris
9/12/2016 10:14:37 PM • Bulova Men's... • Answered on Sep 12, 2016
Mossimo alarm
While in (digital) Clock mode (NOT in alarm setting mode!!!), push the bottom-right button and then the top-right, to toggle alarm on & off.
8/24/2015 12:34:20 PM • Bulova Men's... • Answered on Aug 24, 2015
How do I change my Pasnew PSE 149A to military time?
go to this link to download manual http://pasnew.com/english/edown.aspx
2/12/2014 9:14:54 AM • Bulova Men's... • Answered on Feb 12, 2014
How do you remove back from bulvia watch
Some have a pop off case, find the "lip" on the case back and put a small screw driver or anything else metal that will fit under it and pry it off that way. Others have a screw on case back and will have 6 square slots around the outer edge, you will need a wrench for this that you can find on ebay
1/26/2014 10:07:03 PM • Bulova Men's... • Answered on Jan 26, 2014
2answers
I have a Bulova Accutron
I suggest that you go to their web site http://www.bulova.com/contact/contact.aspx and contact your loca service center. They should be able to advise you.
1/26/2014 9:51:51 PM • Bulova Men's... • Answered on Jan 26, 2014
I just bought a Bulova Super Seville watch how do
Pull the stem out one click, rotate stem clockwise to set day, counter clockwise to set day, pull stem out to second click to set time
2/26/2013 12:51:25 AM • Bulova Men's... • Answered on Feb 26, 2013
Manual for a manual
1/4/2013 11:25:21 AM • Bulova Men's... • Answered on Jan 04, 2013
2answers
Need bezel with lugs
You could always ask the maker (go to Boluva.com and get the address of your nearest service center).
It seems s unlikely that they will be able to help with such an old watch but you never know your luck. I'm sure that they will be pleased to hear that your watch is still working after such a long time!
12/21/2011 2:02:28 AM • Bulova Men's... • Answered on Dec 21, 2011
0answers
I have a bulova accutron
One of the two buttons is a mode button when you push on that button digits on your watch start blinking. Once the digits start blinking keep on pressing the other button till you get the desired digit and then press the mode button again to fix the digits and likewise you can set it for minutes also.
2/23/2011 8:00:55 AM • Bulova Men's... • Answered on Feb 23, 2011
Hi i have a new Bulova 96B141 and was wondering as
If you go to http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=96B141&brand=bulova you will see a menu in the center of the screen. Choose operating instructions and download them.
Have a Merry Christmas!
12/24/2010 12:40:15 PM • Bulova Men's... • Answered on Dec 24, 2010
How do you open the back of a bulova watch
You need a special tool called a case opener, if you flip the watch over you should see 6 square slots on the outer rim, this means that the back case is screwed on and probably has a water proof seal, keep in mind there are different sizes. I suggest you check ebay for watch tools, you might find what you are looking for.
12/17/2010 4:49:42 PM • Bulova Men's... • Answered on Dec 17, 2010
I can't seem to unscrew
Thanks for contacting FIxYa..
You will need to take it to an authorized Bulova retailer to have them use the correct tool to remove your battery.
Best regards. Jewel
9/14/2010 12:53:09 AM • Bulova Men's... • Answered on Sep 14, 2010
Bulova Men's Watch Logo
49 questions posted
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
View Most Popular
Bulova Watches
  • Bulova Watches
Most Popular Question
just bought bulova super seville watch
  • Watches
