20 Most Recent Bulova Crystal 96T63 Watch for Women Questions & Answers
Just replaced the battery on
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
8/19/2010 12:53:56 PM • Bulova Crystal... • Answered on Aug 19, 2010
Adjusting the band on a boluva 96T63
Alllways try screwdriver first. If the pin doesn'y come out when you unscrewing it, that means you have pins instead. Use small steel pin and hammer to drive the pins out. Make sure that the split end comes out of the hole first.
12/17/2008 9:44:33 AM • Bulova Crystal... • Answered on Dec 17, 2008
How about some standard Nd:YVO4 crystal series?
Antyco have a lot of standard series kits of diode pumped laser optics, is's easy to select what you need listed below Part Size (mm) Nd Coatings S1 S2 NYV001 3x3x1 0.5% AR@1064nm, HT@808nm AR@1064nm, NYV002 3x3x1 1% AR@1064nm, HT@808nm AR@1064nm, NYV003 3x3x1 1% HR@1064nm, HT@808nm, AR@1064nm, NYV004 3x3x1 1% HR@1064nm,HT@808nm,HR@532nm AR@1064nm, NYV005 3x3x3 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV006 3x3x3 0.5% HR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV007 3x3x5 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV008 3x3x8 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV009 3x3x12 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV010 3x3x3 1.0% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV011 3x3x3 1.0% HR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV101 3x3x0.5 3.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV102 3x3x1 1.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV103 3x3x1 2.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV104 3x3x3 1.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV105 3x3x5 0.5% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV106 3x3x2 1.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV107 3x3x2 0.5% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm For more: http://antyco.com/
9/23/2016 6:29:06 AM • Bulova Crystal... • Answered on Sep 23, 2016
What is this watch model Caravelle By Bulova c875182 45C04 and 05
Click on the link and ID your watch. The numbers are not identified. If you bought it on eBay, Amazon or anywhere other than a dealer shop, it is a Chinese clone. They make up model numbers for effect and to avoid litigation. https://www.google.com/search?q=Caravelle+By+Bulova+c875182&sca_esv=584988440&rlz=1C1QJDB_enCA643CA644&tbm=isch&sxsrf=AM9HkKkYbdvYgLAR8s9CmNaospXMuyRW9A:1700802670780&source=lnms&sa=X&ved=2ahUKEwjpjJnY79uCAxUGhYkEHbyDDL4Q_AUoAnoECAQQBA&biw=1920&bih=931&dpr=1 ..
11/24/2023 5:14:13 AM • Bulova Watches • Answered on Nov 24, 2023
How do I change battery for bulova b0553 mini grandfather clock?
Locate the battery: Check the back or bottom of the clock for the door. Open the compartment: Use a screwdriver or your fingers to open the compartment door. Remove the old battery: Remove the old battery and dispose of it properly
10/16/2023 5:09:00 AM • Bulova Watches • Answered on Oct 16, 2023
Bulova 98H48. What battery is in it please? I opened the watch up to replace the battery and ended up losing it. Thanks.
They use many, so the answer is always "the same as the one that came out of it". https://www.energizer.com/specialty-battery-finder/bulova-watch-battery-replacement Nothing here, which is odd because that normally works, https://www.google.com/search?q=Bulova+98H48+battery+type Look for tiny engraving next to the battery compartment. Or ask them direct. https://www.bulova.com/ca/en/contact-us.html ..
3/17/2023 1:19:25 AM • Bulova Watches • Answered on Mar 17, 2023
The push button function on swiss model 2423.11 bulova accutron.
Jesus I can't believe no one answered this guy with even an "I don't know." in 6 years. If it's like my watch, it's for synchronizing the second hand. If you press the button on the minute mark from the NIST time web site, when your watch is ten seconds fast, the second hand will stop for ten seconds. This makes your watch match the time clock. The really cool thing is if your watch is SLOW, if you press the button on the minute mark when your watch is twenty seconds behind the NIST time web site, the second hand will SPEED UP until it matches the NIST time. Very cool and this is **totally from my memory** because I just got my watch back from Bulova but I forgot to ask about the button.
1/1/2022 5:02:13 AM • Bulova Watches • Answered on Jan 01, 2022
How to set a Bulova maritime watch
https://www.bulova.com/pages/manuals-parts
User Manuals
Please consult the user manual that was packaged with your Bulova watch. If you don't have your Bulova user manual, please view our STANDARD MANUAL to read general information about how to set and maintain your watch. You may also view or download a manual/PDF with information specific to your watch. Find the style number on the back of your watch case, then simply click on search icon at the top right, type in the style number, and we'll find it immediately. For all other inquiries or assistance, please contact [email protected] or call 800-233-3350. Parts Manuals
9/30/2021 6:04:01 AM • Bulova Watches • Answered on Sep 30, 2021
What battery does the Bulova C837381 take and how do you put back on?
Tip & How-To about Watches Changing Watch Batteries Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10! Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15! Posted by ADMIN... on Dec 31, 2018
6/14/2021 3:57:55 PM • Bulova Watches • Answered on Jun 14, 2021
NEED A BATTERY FOR BULOVA CL437597
https://www.quora.com/How-do-I-know-which-battery-I-need-to-fix-my-bulova-watch I have changed batteries on watches before but none were bulova. I opened the back which you have to do to change battery find what battery you need and order online. I have been able to find at stores year ago but most watches now days people don't change batteries they buy new watches. It is a little harder to find batteries in stores. When you find the type battery google to get the place to buy it. https://www.energizer.com/specialty-battery-finder/bulova-watch-battery-replacement
8/10/2020 7:11:30 AM • Bulova Watches • Answered on Aug 10, 2020
What battery size do I need for a Bulova Caravelle with C975419 on the back plate
take it to MACYs and say , can you pop in a new battery. or any watch repair shop, can. this is very old cheap watch and manuals are not easy to find.
3/1/2020 1:16:49 PM • Bulova Watches • Answered on Mar 01, 2020
2answers
I need a manual for a bulova model 90a07.Is there a manual or download available? It's a cronograph alarm.
https://www.youtube.com/watch?v=UR9yVjrFyiE This is merely a video on how to reset the second hand on your Marine Star. But perhaps it has some information that will be helpful to you.
5/30/2019 3:25:49 PM • Bulova Watches • Answered on May 30, 2019
Bulova Crystal 96T63 Watch for Women Logo
2 questions posted
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
View Most Popular
Crystal Bulova
  • Crystal Bulova
Most Popular Question
just replaced battery
  • Watches
