Panasonic PT-50LC13 50" Rear Projection HDTV Logo
s
shawn lumbard Posted on Feb 12, 2015
How to shut off blue screen that says change bulb
Changed bulb
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
2answers
Panasonic PT-43lc14 blue dots lower left corner of screen
I just changed the lamp bulb. Why do I get a blue screen on the I just changed the lamp bulb. Why do I see a blue screen on my Panasonic PT-43lc14. See photo. attached.
Light bulb icon lite up blue and black screen
Remove main battery and power up, no change! sub out the memory ram one at a time and test each piece, if still no change! laptop will need to be checked.
1helpful
I'm seeing an uneven darker blue or a haze along the bottom after I changed the bulb. Looks like a blue cloud along the bottom darker, very noticable when I first shut the TV off and it blue screens during...
You have something on the lens. If the lens was producing excessive heat it could be the melting around the lens itself, or it could be grease from your finger that was clear until it got hot enough to cook onto the glass. Either way, remove and clean the bulb lens (the one on the bulb you change out when the bulb blows) and then re-clean the focus lens on the front of the projector (the one you turn to focus).
If this doesn't clear it up, look for damage on the focus lens or the bulb lens.
Blue lines on screen...
Try Encompass Parts 1-800-638-3328
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
2answers
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
RCA big screen
More then likely your blue tube is bad.repair cost 350.00 and up.ThankYou for using FixYa and Have a Nice Day.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
