If you have the original Windows CD, put it in the drive and try to boot to the disc. Each computer is different so there will be different methods to achieve this, but if you don't see a prompt to boot to the CD try tapping tab or F8 to see what other options you have for boot order.
If you can boot to CD, see if you can repair your startup, or run a check disk (depending on what version of Windows you're running). If you can give some more detail I can probably help you out better as to what you need to try. Best of luck!
SOURCE: Desktop won't complete boot
Open up the desktop and replace your CMOS battery, or atleast test it and see if the re-booting stops. If not and you have your XP installation disc you may have to do a system repair, start your pc with disc in and press enter when prompted, but make sure that your cd drive is set up as first boot in the bios.
SOURCE: The desktop is empty
First a question; you say you only have the background and cursor does that mean literally everything else is gone including the start button in the lower left and the task manager in the lower right? Or do you mean that all your icons, shortcuts, folders and files you had on your desktop are gone?
SOURCE: t3882 keeps rebooting
there could be possible problems with ur smps... dat wil make it reboot frequently ,cos of low power supply to the board... anyway, first try to reinstall the os...
SOURCE: pc keeps loading and restarting again, it wont go past windows xp
well,eventually if it started several times the good configuration you will take is that also to restart again,it better to move on to safe mode in order to restore your windows normally that process will restore your some missing file to start up.after windows appear.
click start,click all program,click accessories, click system tools,click system restor until system restore appear just select any date that system restore will correspond to your request( I prepare past date)then follow the restore system what to do until it will restart again your PC Observed there will a long time to restart just let it be make the restor system is fixing your start procedure then finish it will now appear your refresh windows.if you shutoff and start again it will put back to normal operation.If the problem occured again some virus is inside your hardisk reformat your windows.
SOURCE: MY EMACHINES COMPUTER IS STUCK IN SAFE MODE
hi ...
whn you say the computer boots up in safe mode..
in this list you should have an option called as load windows normally (similar to this)
use the arrow keys and select it.. and then press enter and please do let us know what happens..
it should ideally work...and if it boots up to your desktop please investigate..
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer
if you need further help with this post a reply
hope this helps you
