20 Most Recent eMachines eMD620-5133 Notebook Questions & Answers
pls help me redfox tablet i reformat then i've lost microsoft virtual wifi miniport adapter and Intel(R) Centrino(R) Wireless-N130 are loss, what can ido?
eMachines... | Answered on Sep 19, 2018
have you tride updating wifi drivers some times this helps get from https://driverscollection.com/?H=D620&By=eMachines and remember always install new software or drivers as Administrator.
eMachines... | Answered on Apr 28, 2016
does any1 have fate the unlock code from wild tangent
eMachines... | Answered on Nov 07, 2015
Hi brian
microsoft virtual wifi miniport drivers can be found at driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
eMachines... | Answered on Nov 07, 2014
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
eMachines... | Answered on Apr 06, 2014
Hi, The BIOS password is a password that you would have set on the laptop to protect the hard drive and during the installation of Windows you would need to key in the BIOS password so that you can go ahead with the installation of the Windows.If incase you have forgot the BIOS password please contact eMachines if the laptop is covered by warranty so that they would be able to assist you remove the password on the computer.If the warranty has expired then you would need to contact a local technician at your place who would assist you reset the BIOS password which would require opening the case of the laptop and reseting certain cables within the laptop. Thank you for your time and best wishes for your effort.
eMachines... | Answered on Dec 04, 2013
Give me some more information about the game...
But if it is an online game (like WOW, LOL,etc.) there is no such a hack i'm sorry, otherwise if it is a game like gta sa, iv , call of duty or any game that is not browser based i can search for it :P Thanks for using fixya!
eMachines... | Answered on Jun 01, 2013
You have been given a cs along with your system, the OS CD. Try to run that and you can restore your system from that CS only.
For further technical assistance you can call us on our toll free no. 877-974-4669.
eMachines... | Answered on Apr 23, 2013
No ideas
Just definite facts
Problem is;
A) Graphics chipset
Or.
B) Video Cable
Or,
C) Screen Inverter
Or,
D) LCD screen
Diagnose
LOT of reading ahead.
1) Graphics chipset:
Connect a VGA monitor to the blue VGA port, on the right side of the laptop.
http://www.geeks.com/largePic_all.asp?invtid=D620-5133-OB&pic=D620-5133-OB-box.jpg
This is a general example of a VGA port (Connector), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA Cable.
Turn the monitor on. If a CRT type allow it to warm up
By factory default settings the display should show on the external monitor.
IF not;
There are at least 3 display options;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the Same time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
No display, (Or solid white), on external VGA monitor, suggests problem with graphics chipset. If this is the problem post back in a Comment.
Good display?
Problem is Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
There are no eMachines D620 service manuals, available on the internet for free that I have seen. Supposedly a few paid for versions, but I have my reservations about that.
(Probably a Generic User Guide, which you can get for free)
I also have never worked on this model yet.
But this isn't rocket science, and this isn't 'my first rodeo'.
2) Video Cable:
The Video Cable plugs into the motherboard, in an area under the Keyboard, and under the Palm Rest Cover.
Judging by;
A) Top View of motherboard,
http://www.ebay.com/itm/eMachine-D620-Motherboard-48-4BC01-011-MBN240100-08226-1-Yukon-MB-/121076931939?pt=US_Motherboard_CPU_Combos&hash=item1c30bf5d63
Set your mouse cursor in the middle of the photo. This enables the Zoom In feature.
Looking at the rectangular metal plate, with the opening in the middle of it; come from the Top/Left corner.
See what appears to be a fairly long white strip?
That is where the Video Cable plugs into the motherboard.
Now here is the D620 with the Keyboard removed. (And Display Assembly),
http://www.ebay.com/itm/eMachines-D620-Motherboard-CPU-base-assembly-/110847874891?pt=Motherboards&hash=item19cf0c574b
Here you see the white connector again.
Middle, and towards the Top; in the small rectangular opening.
The Palm Rest Cover has to be removed, to access the Keyboard Cable's motherboard connector. This connector.
Going on....
The Video Cable then goes up by the left Hinge, and then up into the Display Assembly.
From there the main portion of the Video Cable, connects to the back of the LCD screen.
There is also a separate small cable, coming from the Video Cable; that connects to one side of the screen Inverter.
Example of the Video Cable,
http://www.ebay.com/itm/eMachines-D620-LCD-Video-Cable-50-4BC03-021-/130862506637?pt=US_Video_Cables_Adapters&hash=item1e7803628d
The white connector you see at the bottom, with the black pull strip; is the motherboard plug connector.
The small cable extending to the Right, connects to the screen Inverter.
The large connector shown at Top, connects to the back of the LCD screen.
Just from normal repeated opening, and closing of the laptop; the Video Cable may become pulled on, and/or pinched.
This can cause a loose connection at the motherboard side, or LCD screen side.
Screen Inverter cable connection may be pulled loose also
Can also cause damage to the Video Cable. Stretched/Broken wires
The procedure is to;
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) PHYSICALLY check to see if the motherboard connection is tight. Try to plug in tighter.
Reinstall power. Turn laptop on see if this was the problem.
No?
Remove all power again. This time remove the Display Bezel, and see if the Screen Inverter cable is connected tightly.
At this point it is just going to be a visual observation, and record.
Next is to check the LCD screen connection of the Video Cable, and it may loosen the Screen Inverter connection, anyway.
[The plastic frame in front of the LCD screen is the Display Bezel,
http://www.ebay.com/itm/eMachines-D620-LCD-Screen-Bezel-41-4BC01-001-/300798380595?pt=UK_Computing_Other_Computing_Networking&hash=item4608fb0a33 ]
If plugging the connections of the Video Cable in tighter, does no good; the Video Cable is then checked for continuity.
A multimeter is used, and set on OHM's. (1K)
Electricity is sent through each wire. The reading itself isn't as important, as just seeing IF there is a reading.
No reading indicates stretched/broken wire.
You can take the Video Cable, down to the nearest small computer repair shop; and have the resident tech check it out for a few bucks.
The Video Cable MUST be ruled out as the problem, before going on. Otherwise you may be buying parts needlessly.
(LCD screen? Around $70 to $100. You have seen the price of a Video Cable)
Video Cable proves to be good? Go on.
3) Screen Inverter:
The screen Inverter is located behind the Display Bezel, and mounted to the bottom of the LCD screen. (Screen Frame)
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Do to this, the ease of access to replace, and the general low cost; the screen Inverter is just replaced,
http://www.ebay.com/itm/LCD-Power-Inverter-Board-for-eMachines-D620-Backlight-Replacement-for-Screen-/120819595221?pt=US_Laptop_Screens_LCD_Panels&hash=item1c2168b7d5
If this doesn't repair the problem, the problem is the LCD screen.
Replace.
I can guide you, and I believe step by step; if you wish to attempt repair.
Post back in a Comment.
Regards,
joecoolvette
eMachines... | Answered on Mar 16, 2013
in your sart menu using the search tool search for rundll 32.exe
eMachines... | Answered on Jan 31, 2013
Go here and click on notebook and follow then confirm
http://support.gateway.com/us/en/emac/product/default.aspx
Hope this works for you..
eMachines... | Answered on Nov 25, 2012
If you using your nb with network boot os media, please re check your cable connection to server media. Or
If you using internal hardisk for boot up your system operational you might have accidentally change Boot Order on your BIOS setup.
How to enter bios:
On power on you might see instruction on the bottom of your screen like => Press F2 to enter setup or some thing like that.
Make sure to disable Network Boot option, or move it to the bottom / last of Boot List Option
Press F10 to save it, and reboot
eMachines... | Answered on Nov 15, 2012
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
eMachines... | Answered on Sep 20, 2012
Driver problem
eMachines... | Answered on Jul 21, 2012
Windows Password Recovery is right what you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK!
eMachines... | Answered on Jul 02, 2012
Let's hope that this is not a lamp part going out. Press the FN blue Key and look for an icon Blue at the top of the keyboard that look either like a brightness sunshine picture, make sure to hold the FN key down as you press the sunshine brighter key tap it until the light on the screen gets brighter. John
eMachines... | Answered on Apr 13, 2012
Key Pad or Touchpad? Is it that the mouse pointer is frozen and does not work? If so, look at the middle of the touchpad at the top of it and there might be a button there that lets you toggle the touchpad between locked and unlocked.
Sometimes there might be a set of keystrokes you will have to hit to lock or unlock the keypad. Most times you will have to Press and Hold the Alt, FN or Ctrl key then hit the key (most times one of the F1 thru F12 keys) that controls the keypad. The key that controls the keypad will have the icon of a finger inside or pointing at a square that represents the keypad. On one laptop recently that I worked on it was toggled by Pressing and Holding the ALT key then hit the F6 key. F6 had a finger pointing at a square area representing the touchpad.
eMachines... | Answered on Apr 08, 2012
Windows Login Password Recovery is right what you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
eMachines... | Answered on Feb 13, 2012
eMachines eMD620-5133 Notebook Logo
Popular Tags
184 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Thomas F. Schneider
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
driver microsoft virtual wifi miniport
  • Computers & Internet
