Posted on Jan 25, 2015
My Innovated Technology 5 in 1 player will not work
Tried turning it on and off, moved it to a different area, keep getting a message-busycd
  • mare4456 Jan 25, 2015
    This is the model I need help with
stephen Kiarie
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 32 Answers
  • Posted on Jan 29, 2015
stephen Kiarie
Contributor
Level 1:
Cheetah:
Night Owl:
Answers
32
Questions
Helped
6629
Points
62
Open it up and isolate the power to the cd player side and continue with your trouble shooting .... best of luck.
How to solve error message C00D11B1
Computer program errors are discussable. First, the programs require compatibility to the entire computer system to take effects either as downloads or installation from internet of disk drives. Computer software programs have compatibility versions to each system innovated. For example, windows media player version 9 or earlier is installable on older computers where version 10 above compatible to recent innovated computers. In situations that computer least captures the window media player effect requires acquiring another media player. For example, real one media player has the compatibilities to generic device either Microsoft of apple Mac computers. Also, available are generic media programs that least requires compatibilities to install however least has satisfactory expectations discussable. Error observations are solvable either as attaining an alternate program software least incompatible or capturing a computer that is compatible to the program requesting installation.
It won't turn on or charge
Find a technician or electronic repair shop and let them check it for you, or try to get a new charger and test if it would work
2answers
Samsung DVD-VR375 - can't chage from region 1 to region free
I used this and it worked for me!:
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
2helpful
2answers
How to change area code on dvd player
I've tried one like this on mine which had the same problem and it workded.
go to this website for your dvd player (you can also search other dvd players on this site) http://www.videohelp.com/dvdhacks?dvdplayer=LG+V181+&hits=50
Philips cdr 606 Recorder. I keep geting a message saying Reading and the Insert disk, after I have inserted a disk.. Tried different disks, also a lens cleaner but keep getting the same message.. can...
The problem of reading, insert disk, is that the mechanism of the player ....the problem is not on the lens its in your player mechanism. I suggest you that, in the mechanism which the lens are moving if u see a roller that is the problem and its already in dirt and dust..u better clean that by using a lighter fluid and then take the old grease change it with new one with good quality..after that it will be okay.
2answers
Setting up my zune with my pc
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Just the screen lightened
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
2answers
 Grubhead
Grubhead
SmartAviator
SmartAviator
