SOURCE: CKO In-Car DVD Player Distortion (CKOMMP001)
you need something called a "Line Output Converter". It will reduce the speaker level signal and is usually adjustable. Most car audio shops have them for about $20.
SOURCE: Screen is distorted!!!! HELP!!!!!!!!
Bad LCD Display. If Have repaired 4 units in past year with this failure. Looks like video is out of sync. Failure can be Intermittent or Constant. Any Questions [email protected]
SOURCE: Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
