Motor PERKINS serial n 4000
I don't understand what do you mean. The genset you buy is Perkins 4000 Series diesel generator and it cannot run normally, right? If so, try to check the following issues:
1. Battery failure
2. Low coolant level
3. Low coolant temp alarm
4. Oil, fuel or coolant leaks
5. Control not in auto
6. Air in the fuel system
7. Ran out of fuel
8. High fuel level alarm
9. Breaker trip
Helpful article Why Diesel Generator Fail to Start
Im not sure are you asking about Phasing ? on a three phase gen set , yes extreme care needs be taken if you need to start one genset before shutting one off , in this case a Phase/sync meter will need to be used to keep from surging all the loads connected to genset , also all three phases of each genset needs to be "In sync" to be able to use a transfer from one genset to another , in sync refers to peek waveform on each genset, needs to be in perfect time or an "ARC" will occur , that could be detrimental to the connected loads if there sensative to this type
