Electrical Supplies Logo
o
oc vermeulen Posted on Jan 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What applians can I use on a stramm 2.5 kw generator and how many
Nothing
Harrie
Level 3:
Top Expert:
  • Master 6,746 Answers
  • Posted on Jan 15, 2015
 Harrie
Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1286076
Points
83153
You can run 100, 25 watt bulbs, Or one washing machine, 1000 2,5 watt LED lamps, or on or two air conditioners. It is 2500 watt per hour it can give.
Stramm 1.0kw generator wont start no spark
Here is a suport website: www.dieselgeneratortech.com
CAN YOU EMAIL THE MANUAL FOR STRAMM PETROL GENERATOR ELECTRIC START SMM3000 [email protected]
Go to google put in the item you're looking for and it will be there for you
This is my generator that should run everything in my trailer
the photo shows nothing of importance and you have no question
ask the question again stating the kva/kw of the generator with what you will be running in the trailer ( all items at once) and ask is the generator big enough for the trailer.
Instruction manual for stramm 2.5kw generator
Generator running but doesnt generate power
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
1helpful
2answers
Owners manual and starting instructions
What model is it? I need more information please
1helpful
Kubota generator a45 3 120 manuals
Not a very good model number. 45KW generaters don't come in 3 phase and 120 volts.
Try one of these places and see if they can get what you need:
http://www.kubotaengine.com/products/ge_lineup.html
http://www.dieselgeneratorsmiami.com/powergeneral/2/45-kw-to-95-kw-diesel-generators.html
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
