Re: HL32V86 Hisense 32' stuck on standby wont...
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
hello, i've repairing one at the minute with same fault, but you could try this i'm not going to say it will work but can try it. turn the tv off and back on again with the tv on press the menu button while taking the power lead out keep your finger pressed on the menu button and replug the lead back in if it works the menu will come back on the screen you might need to retune it back in. i hope it works regardsshaun
The unit has a fault on its power board and sustain board. It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
You are only have 5v standby circuit working, the problem can be in the main control board (not sending signal to turn on the main power supply sections) or the main power supply sections are bad.
