Hi!
The Print Screen key on your computer doesn't really print the screen. What it does it take a picture of the screen, and puts it into your clipboard.
You can then Paste (Control-V) the image into a program such as Paint or Word.
Print Screen by itself does a full screen image capture.
Control-Print Screen only takes a picture of the topmost window.
I hope this helps.
As mentioned above the Print Screen or PrtSc button isn't for actually printing. What it is used for is taking a screen shot of your computer screen. To see how to use is click the link below:
https://youtu.be/fkIecJ7lznQ
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
Whatever happened to the Print Screen key??
If you did computers back in the 80's (DOS days) you probably remember using the Print Screen key on your keyboard to print a copy of whatever was on the monitor screen at that time to your printer. It wasn't used that much because back in those days it took forever for a dot matrix printer to print out the entire monitor screen. However, it came in handy once and awhile.
Microsoft has turned the key into into a "Snapshot key" which, as that term implies, takes a snapshot of the monitor screen.
After taking the snapshot, in XP simply click on Start, All Programs, Accessories and Paint. Then click on Edit followed by Paste and Voila! There's your screen snapshot in living color staring you in the face!
Now you can use "Save As" and save it with a .jpg/tif extension (etc.) and/or send it to your printer using File, Print.
If your keyboard Print Screen key performs more than one function you will have to experiment a little to get it the key to perform the Print Screen Function. Try holding down the ALT, SHIFT, or CTRL key (or any "special" keys unique to your keyboard) when you hit the Print Screen key in order to get the key to perform its Print Screen function.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
