Unplug every thing than plug in again
SOURCE: Sony KDP-65S550 red light keeps blinking
How many times is the LED blinking in between pauses? that is possibly a error code if you can determine the number of blinks.
SOURCE: Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
SOURCE: sony kdp-57ws550. Turn on tv = no picture, have
You have to count how many times it blinks. It is a service code. The main thing that goes on these is the convergence chips. If you had the back off doing any type of repair, recheck your plugs. Odds are, you crossed one.
SOURCE: KDP-51WS655 OR KDP-57WS655 57 inch HD PROJECTION
check the power switch for dry joints and resolder all joints if it still doesnt work check power board for dry joints as this is a common problem let me know how u go
SOURCE: TV will not come on, LED light flashes 10 times,
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
