The TV would get horizontal lines and would flash solid colors of blue green or red and then shut off. I was getting nine flashes and now the green crt is not lighting up but the blue and red are. Any ideas
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Do you have a green light that flashes and then goes off? You need instalation kit# 4835 310 57673, The chassis# is probably an L04.1U AA, correct? What you will do is correct the horizontal timing so everything will come on at the same time. After you install you will see red, blue, and green horizontal lines at the top of your screen.......this is normal when you power up your TV. This is a factory authorized repair.
Five blinks means - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Please rate this solution as FixYa if found useful.
Your green CRT socket may have a solder crack, or it could be the CRT developing a short. You can switch the green CRT socket with the one from the red RT and see if it still flashes green. If it does then its your CRT, But if it now flashes Red, Its a problem in the green drive circuitry.Thts the quickest way to locate exactly where your trouble is. If you need anything further let me know.
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
