I have a compaq evo n1020v, its not able to boot there is no display and no keyboard lights when i start up the laptop, I have very important data sitting in it. I have tried things like removing the hard drive, changing the memory from one slot to another but with no luck please help. Thanks in advance.
You have a sick laptop, could be simply a faulty power adapter to a faulty motherboard. The Evo is old and probably not worth fixing, better to put your money towards a new laptop.
There is a way to retrieve data from your hard drive provided it is not faulty.
Remove the hard drive from the laptop and connect it to an USB hard drive adapter. Insert the adapter into a working computer's USB port and the computer will see this as an external hard drive. You can then open the folders and view your files. Copy the various folders and files you require to a USB memory stick and/or burn these to a CD etc.
It pays to backup your data regurarly because if the hard disk fails and this can happen unexpectedly, you will lose your data.
If the hard drive is faulty, there are companies that can retrieve data from faulty hard drivers, but it will cost you an arm and a leg for their services.
