20 Most Recent
Compaq Evo N1020V PC Notebook Questions & Answers
Video graphics
You may want to go to hp website (www.hp.com) and download latest drivers for your product
I have a Compaq N1020v with a 14.1 display. The
It depends on how "adaptable" the mounts on the "surround" of the LCD screen, i.e., whether the one "surround" was used by COMPAQ for both 14" and 15" LCD screens, or whether the part-numbers were different.
Compaq Evo N1020v.
This is a hardware problem that will require repair. Please contact yor manufacturer for assistance.
My laptop will not turn on
Try another AC Adapter with the battery taken out of the laptop. If the light still blinks then that means the motherboard is bad and would need to be replaced.
Processor is not heating no display ?
Take a flash light (seriously) when its on point it at the screen do you see something? I betcha you got a bad back light or a inverter issue.
also you can try to hook up a external monitor maybe? if that comes on then you know you got a display fault.
when in doubt please contact manufacture support or bring it into a local repair shop for a estimate.
My screen will not turn on
Be considerate your solution was free, please leave a rating and feedback for your free solution, thanks Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Compaq Evo N1020v operating system not found.
Make sure that your CD is Bootable. Now you will need to do settings in BIOS to boot from CD..
1. Power ON the computer and Press "Delete Key" or F1 or F2 or F10 Key to enter in BIOS.
2. Goto Boot Menu Options
3. Select First Boot Device to CD / DVD
4. Second Second Boot Device to HDD
Now Save Settings and exit . it will reboot computer . If your CD is bootable then it will ask to boot from cd message.
Option 2 :
You can try by pressing F12 or F11 key simultaneouslty after power ON computer. It will display Boot Menu so from there you can select "CD/ DVD Drive " and press enter then it will boot from computer.
It will glad to help you further if your problem doesnot get resolved.
Slow Computer
Could be lots of reasons. First thing you're gonna want to do is backup your important files.
I'd say it's time for a format / re-install.
You could try figuring out the exact problem(s) but it's much smarter to do what I suggested.
Trust me.
My compaq will not connect to the internet
thus the router of the area where you are located is turn on,? thus your computer able to find the connection but cannot be connected?
try to ask other people first if they where able to connect to the site where you want to access,
try to see if the network has alimited access or need some access code for you to be connected
post your reply
I want to put ram in my laptop evo 1020v, but he
When you say that it only recognizes 512 MB, I am assuming that this is after you installed the RAM? - How much did you have before you installed it? And how much did you install?
Sometimes it is as simple as making sure that the RAM chip is pushed in far enough. Make sure the chip is pushed in securely. Sometimes you will hear a click when it is in far enough. If it is not, the laptop will not recognize it.
Hope that helps.
