Dehumidifiers Logo
M
MARV SMOKER Posted on Oct 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my dehumidifier power off and not start up again when I set the timer for 2 hours or 4 hours? (Model GL-DEH-70-2a)
Nancy Ellis
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 46 Answers
  • Posted on Oct 27, 2014
Nancy Ellis
Expert
Level 2:
New Friend:
Cheetah:
Answers
46
Questions
Helped
8822
Points
135
1 Related Answer
Anonymous
  • 910 Answers
  • Posted on Jun 25, 2011
SOURCE: timer switch mode is inoperable.
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
How do you program it to run for "X" number of
This can be confusing and you're not the first to ask. To put it simply you can only program the timer to turn the unit OFF while it's running. For it to turn ON again, say in 4 hours. You have to wait until the unit is in standby mode, then advance the timer to 4 hours. Four hours later it will turn ON and start functioning.
I hope this helps you and thanks for choosing FixYa.
1helpful
We recently purchased a darby dehumidifier-#DDR6009EE-60 pint- and have not been able to program the equip.Can you help us. We need to know how to adjust it so that it will go on and off after specific...
I beleive there is some confusion about the Timer Mode. It can only be set to turn the unit OFF after a selected time period. For example: It's 6pm you want the unit to turn OFF at 10pm. You press the Timer button on the unit itself, in increments, until it reaches 4 hours. At 10pm the unit will turn OFF. As a safety feature, it does not have the capability to turn the unit ON at a selected time and then OFF again. In the interim, until you get really familiar with all the functions of this model, use the control pad on the unit, rather than the remote control.
I hope this helped you understand what the timer does and how to activate & set it.
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
1helpful
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
How do you set it to come on and off automatically
Generally, setting the humidity extraction level to what you want (Remember, the lower the percentage, the more humidity will be extracted) and not operating it in continual run mode will do the trick. Most humidifiers can be set to run in a 2 hour or 4 hour intervals. That means it will run as necessary for 2 or 4 hours and then turn OFF. It will turn back ON again, when the humidity level in the home rises above the setting you have it on.
3helpful
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
1: 42 25805 DEHUM 50 PT ELEC w/PUMP Lost manual - how do we set the timer to shut off at night?
How to program the delayed start function: From the OFF Position.
1) With the unit OFF press the clock/timer button and use the and - buttons to set the number of hours after which the appliance should start functioning.
How to program the delayed stop function: From the ON Position
1) Press the clock/timer button and use the and - button to set the number of hours after which the appliance should stop functioning.
2) Ont the left side the display will show the number of hours to start/stop and the dot under the clock/timer symbol indicates that the timer has been selected.
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
