Dryers Logo
Robert Henderson Posted on Aug 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a Hoover TC 650 tumble dryer which won't collect water in the bottom container, everything else works fine and I've already tried cleaning everything I can including the condenser but no luck..I wanted to try disassembling it to check for more blockages but the whole unit seems to be welded except for the top which doesn't help..does anyone have any suggestions? Thanks!
paul
Level 3:
  • Master 825 Answers
  • Posted on Aug 28, 2017
paul
Master
Level 3:
Answers
825
Questions
0
Helped
174153
Points
2202
Check the pump is working
cheers
Candy heat pump tumble dryer not collecting water and taking forever to dry!
Condenser dryers are simple in operation. They use a heater element to force hot air to heat the clothes and turn the water to steam. That steam is turned back into water by drawing cold air into the machine and over the heat exchanger unit and into the drum. The problems with them is that they are slow to dry.
Your best bet is to call for service, and the problem is likely the sensor probe or one of the thermal cut out.
https://www.4candy.co.uk/tumble-dryer/ro-h10a2tce-80-31101805/catalogue.pl?path=111515,111515&model_ref=14378839&page=2
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
3helpful
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
1helpful
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
5helpful
2answers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
7helpful
2answers
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Leaking condenser tumble dryer
i have the same problem i need help sick of putting towels down infront of it
Top Dryers Experts
john h
