No electricity
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
SOURCE: need manual for my Coleman Powermate generator
Get model number and go to: http://www.powermate.com/productmanuals.php?cat_id=3
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
SOURCE: No power produced by All Power America 3500 Watt Generator
see if the breakers have been reset.
SOURCE: Older Coleman 3500 Watt generator, sitting for
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
SOURCE: I have a Nikota electric generator 3500 watt 6.5
I also have a NIkota 3500 generator, which had a carberator problem. I just ordered a new carb from Yilong-motor.com in China. They may be able to help you. RJL
