My washer and intermittent switch on my wiper will not work on my Mercedes c280
SOURCE: 2000 Jeep Cherokee Sport, window washing does not work
the little pump inside the washer fluid reservoir is bad, replace it
SOURCE: I have a 1994 Mercedes C280 I need a ignition wire diagram
hi,plastic house have number,1-yellow wire,2-red,3-gray,4-gray/violet,6-gray/green,7-gray/yellow,8-gray,9-brown,10-gray/white,ty
SOURCE: how do you time a 1995 Mercedes C280 inline 6 cyl?
hi,pls. remove the cylinder head cover,try to rotate the crankshaft on ot position,then look the hole 5mm in intake and exhaust sprocket,install 2 pcs. of 5mm pin with align on surface of cylinder head,ot on crankshaft pulley and two sprocket lock in the surface of head ,you have a104.941 engine,ty
SOURCE: I have a 1995 Mercedes C280 and the windshield
You need to remove the cover at the base of the blade and oil or grease the mecanism that makes the wiper move up and down and it moves across the windshield. It is dried out and sticking.
SOURCE: ABS light intermittent on 1995 Mercedes C280
hello,good day,try to clean your abs sensor and rotor,apply with wd 40 then cean with compress air,also check electrical connection,for your radio please recheck the power supply specially the parking light wiring,ty
