You first need to make sure you have water pressure from the hot and the cold. If you have pressure from both and still have almost no water pressure, it could be a clogged aerator. If this is not the case, then there is most likely an obstruction in the line that carries the mixed water to the spray head and can sometimes be cleared by removing the ceramic valve and shooting compressed air through the hose from the spray end towards the ceramic valve opening.
Check the inside of the faucet for debris blocking the cartridge or the inlets.
SOURCE: kohler forte single control kitchen, low colder water pressure
1. If it is old enough, it is time to replace the control cartridge.
2. Check your supply stops under the counter, check that they are both supplying full pressure.
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
SOURCE: Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
SOURCE: Kohler Fairfax kitchen faucet has
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
SOURCE: I recently removed and reinstalled my kitchen
take the unit apart, starting with the handles and check for small rocks or derbis blocking flow.
