20 Most Recent
Kohler K-12176-PB Fairfax Single Handle Kitchen Faucet With Side Spray Poli... Questions & Answers
How to remove the handle from a kohler faucet?
Once you have removed the screw from the handle, you may be able to gently pull the handle away from the valve. Some handles may have a small set screw on the side that needs to be loosened first. If the handle does not easily come off, gently tap it with a soft rubber mallet or use a handle puller tool to carefully remove it. If the handle is still stuck, consult the manufacturer's instructions or a plumber for further assistance.
1/29/2023 12:57:38 PM •
Kohler...
Answered
on Jan 29, 2023
How to remove the handle on a Kohler 12176?
To remove the handle on a Kohler 12176, follow these steps:
- Turn off the water supply to the faucet.
- Look for a screw or set screw on the handle that is holding it in place.
- If there is a screw, use a screwdriver to loosen and remove it.
- If there is no screw, use a handle puller tool to gently pry off the handle.
- Once the handle is removed, you can access the valve stem and replace any damaged parts if necessary.
Note: If you are unsure about the process, consult the Kohler 12176 owner's manual for specific instructions or contact a professional plumber for assistance.
1/29/2023 12:57:13 PM •
Kohler...
Answered
on Jan 29, 2023
I have a Kohler Fairfax 12176 kitchen faucet and
Kohler K-79402-CP aerator kit
Kohler K-78250
Kohler 1001100
You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
K-GP77548
$14.80 List Price
Call Kohler if you need more info.
12/17/2017 3:48:20 PM •
Kohler...
Answered
on Dec 17, 2017
We need an expanded view
Go to kohler web site and request a parts break down of that model they should be able to e-mail you a diagram and provide parts needed at little or no cost if you are firm about not using their product again because of bad experience with this faucet.
6/12/2011 5:45:57 PM •
Kohler...
Answered
on Jun 12, 2011
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
8/17/2010 5:42:16 AM •
Kohler...
Answered
on Aug 17, 2010
Hi just moved in new home love it but the water
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
6/15/2010 3:59:51 AM •
Kohler...
Answered
on Jun 15, 2010
Faucet installed 9/94 and still looks like new.
Try tighten the hoses, if this don't work the seal in hose connectors may need replaced, very simple and cheap to replace. over time the hot water will wear down the seal it will go bad with pressure and water period. It's a good thing to change these all while you are there.
1/18/2010 1:29:14 AM •
Kohler...
Answered
on Jan 18, 2010
The faucet leaks around the bottom when turning
Yes- a handle puller is required. My husband is a plumber. He says to go to a plumbing supply store to buy one. Also, u need to take off the brass clip with a screwdriver. It pries out. Good luck!
1/4/2010 10:49:47 PM •
Kohler...
Answered
on Jan 04, 2010
Faucet is leaking up from the sleeve. I remove the
If it's the handle and u can't get it off b/c of sediment then pour hot water on the handle and gently pry off. If that doesn't work then get a handle puller from a plumbing supply store
1/4/2010 8:51:19 PM •
Kohler...
Answered
on Jan 04, 2010
My faucet is barely letting water out
If you have checked the head then that is ruled out. I assume that all the other faucets in the house are okay. The problem is in the small passageways inside the faucet, if both the hot and cold are slow then it is probably in the one going to the spout. If you remove the heandle you can often pull the spout up and over the guts of the faucet. Check for an obstruction in the hole going to the spout. Also blow out the spout to make sure that it is free of debris.
Very small amounts of debris can make a faucet very slow.
11/27/2009 4:34:19 PM •
Kohler...
Answered
on Nov 27, 2009
How remove it to fix a leak
Remove top handle and lock nut and remove plastic cartridge buy the cartridge it has detailed instructions better yet call 1-800-4-KOHLER and they will mail you a free replacement
11/15/2009 6:34:33 AM •
Kohler...
Answered
on Nov 15, 2009
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
