Yes, on two conditions:
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
