20 Most Recent
KLH HTA-4100 System Questions & Answers
Subwoofer VERY weak
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
I just need a diagram on hooking it up corectly.
looked for a while for a manual but could find no reference to it, however set up of this system should be self explanatory:
assuming speakers are identified then it is simply a case of connecting the right speaker to the right output on the sub.
Rear speakers tend to use different frequencys from the front speakers so if you cable them incorrectly, it wouldn't harm the system, just probably sound rubbish.............
