20 Most Recent Acoustic Research S108PS Subwoofer Questions & Answers
When I turn the gain
Open up the sub and check the filter capacitors in the power supply section.
In fact , check all the capacitors to see if any are bulging at the top, or leaking out the bottom.
The most likely suspects will be the filter caps right after the bridge rectifier though.
If that all looks good, do a resistance check on your ground leads between the sub and signal source. A bad ground can cause a signal hum too.
7/11/2011 3:29:03 AM • Acoustic... • Answered on Jul 11, 2011
I have a s108sp subwoofer
Hey there houleo!
If your subwoofer has a stereo input and stereo outputs, then it's a good idea to send the signal from your receiver to the sub, then out to the other speakers you have hooked up. Some subwoofers will take the low frequencies out of the signal to the left and right speakers, so that the sub handles it alone. This often gives a nice crisp sound.
Reciever/amplifier
l l l l V V Subwoofer l l l L------> Right speaker
V Left speaker
If this helps you out, I'd appreciate if you rated me well :) If you've got any more questions, feel free to ask! Cheers! -The Chicken
5/26/2011 4:35:16 AM • Acoustic... • Answered on May 26, 2011
I just got a Acoustic
What makes you feel that isn't right?
You can't just slap a sub onto a receiver and have it work optimally (if at all). The receiver must typically be configured to know it has a sub, then bass managment and sharing decisions must be made, then crossover frequency choices and levels adjusted to match it all up.
All self-powered amps work that way.
Have you looked at the manual for your JVC?
4/20/2011 2:15:51 AM • Acoustic... • Answered on Apr 20, 2011
The capacitor for the subwoofer
http://www.parts-express.com
check this site out i think you'll find what you need there.
11/6/2010 3:24:53 AM • Acoustic... • Answered on Nov 06, 2010
I get no sound at all. The auto on light turns
I should look at the main semi-conductor (perhaps on a heatsink) as being the most likely cause of it's failure.
2/15/2010 1:01:45 AM • Acoustic... • Answered on Feb 15, 2010
How do I connect my
If your tuner has a sub out you use that together with a single rca cable for the signel
1/2/2009 2:23:34 AM • Acoustic... • Answered on Jan 02, 2009
3answers
Acoustic research subwoofer s108ps has a burnt capacitor
HI,
I'll let you know if the service manual is available for this model.
6/23/2008 11:26:27 AM • Acoustic... • Answered on Jun 23, 2008
I have a pair of acoustic research "active
DC 12v adapters are common and I think that would work. The similar "Powered Partner" speakers used a 14v DC adapter. Just check the size of the plug and the configuration (center pin is +). Radio Shack and other sellers have universal adapters.
12/2/2015 9:14:45 PM • Acoustic... • Answered on Dec 02, 2015
0answers
I have 1 speaker of Acoustic Research of 312 HO.
you have only one? or one pair? this standing speaker need a Amp to drive.
2/4/2014 12:10:45 AM • Acoustic... • Answered on Feb 04, 2014
What is the easiest way to clean potentiometers in
Not recommended, market you can find spray type contact cleaner. Brasso is oil base may worsen your problem. Better solution is replace the part.
2/4/2014 12:09:12 AM • Acoustic... • Answered on Feb 04, 2014
Subwoofer wont power auto on
your question too brief, no one can help. be more details so that can understand on your problem. or else there may have too many possibility to cause the problem happen.
2/4/2014 12:03:01 AM • Acoustic... • Answered on Feb 04, 2014
Acoustic Research S108PS Subwoofer Logo
Popular Tags
9 questions posted
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Acoustic Research Audio Players & Recorders
Most Popular Question
when turn gain
  • Audio Players & Recorders
