What can I do to fix this issue asap? Thank you for your time
There is a small control board attached under the directional pad. It sounds like it has come loose from the housing. You can get to it one of two ways. You can unscrew all of the back cover screws on the console and then pop the front overlay off using the tabs under the back cover or you can get your fingernails under the edge of the plastic on the front display and pop it off that way. Precor would not approve of doing it that way but it won't hurt the display. The small D-pad pca can be easily snapped back into place. If you get to the pca and its still secured in the D-pad, the control board itself may be bad.
SOURCE: My Precor 9.21 si Treadmill shuts down upon
Hey Doug,
Just wondering has this unit ever had the running deck flipped over if not this may be sighs of worn deck or belt or both! What is starting to happen is that at the higher speed the unit is starting to draw more current, so the motrol control board will sense this and will shut down so it won't damage either the motor or board. What starts as an occassional shut down will progressively become more frequent. Simple test is put your hand palm down between the belt and deck,if you feel uneven ridges then the deck needs to be flipped over and when you pull out your hand out and their is a black sooty film on the back of it ,then that seals it this means that the composite material is being shaved off. Most likely the belt will have a smooth glazed feeling in the middle part of it. and well also need replacing.
SOURCE: the speed arrow. when I
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1
Stand on the side rails of the treadmill for safety purposes. Remove the safety key.
Step 2 Press and hold the two
incline buttons. The incline buttons are blue and on the left side of
the display. Hold the up and down button simultaneously. Release the
buttons when the display reads "Calibration."
Step 3 Press the green start
button located either above or below the large, red stop button
(depending on your model). Stay on the side rails as the treadmill belt
begins to move. Both the speed and incline should go through their full
range from lowest to highest, and then back down again.
Step 4 Repeat the process if the
display does not read "Calibration Successful.
SOURCE: I currently replaced the walking
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the
treadmill. The belt is properly aligned at the factory. However, during shipping and
handling or by use on an uneven surface, the belt may move off center and
require a few simple adjustments.
Before aligning the running belt, check its operation by following the procedure in
Checking the Alignment of the Running Belt. If you determine that the belt needs
alignment, follow the instructions here.
CAUTION: Special care must be taken when aligning the running belt. Turn
OFF the treadmill while adjusting or working near the rear roller. Remove
any loose clothing and tie back your hair. Be very careful to keep your
finger or any other object clear of the belt and rollers, especially in front of
the roller and behind the deck. The treadmill will not stop immediately if an
object becomes caught in the belt or rollers.
Realigning the belt takes a few simple adjustments. If you are unsure about this
procedure, call Precor Customer Support (see Obtaining Service.)
Take the following steps to align the running belt on the treadmill. To ensure your
safety, make all adjustments while the treadmill is OFF.
1. Make sure the treadmill is OFF and the running belt has completely stopped.
2. Locate the right belt adjustment bolt in the rear end cap of the treadmill.
(To determine left and right, stand at the rear of the treadmill and face the
display.) See Diagram 24. The direction you turn the bolt depends on how
the belt is tracking. Make all belt adjustments on the right rear corner bolt
using the hex key provided.
• If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise,
which moves the running belt to the left.
• If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise;
this moves the belt to the right.
Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening
the bolt can damage the treadmill.
3. Turn the unit ON.
4. Stand beside the treadmill and press QUICKSTART.
5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??².
The running belt starts automatically after the 3-second countdown appears on
the display.
6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph).
7. Walk around to the rear of the unit and observe the running belt for a few
minutes. The belt should run centered along the running bed. If the belt drifts
off center, you will need to make adjustments.
CAUTION: If you hear any chafing or the running belt appears to be
getting damaged, stop the running belt immediately by pressing the
red STOP button. Contact Precor Customer Support.
8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt
is properly aligned.
9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill.
Tighten any loose fasteners or other components on the equipment. If you
hear unusual noises or you feel that the treadmill is in need of repair or service,
contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again.
a) See if the breaker of Home is tripped?
b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little.
Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA
Managua, Nicaragua. C.A.
SOURCE: precor c954i can speed up but cant reduce the speed
Dear Sir:
Please adjust the speed sensor see the diagram attached.
After RUN the software calibration for easy diagnostic and troubleshooting
See my personal TIPS FOR Help.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
