SOURCE: Promaster Spectrum 7 Lens
I believe Promaster does not have any lenses with focus motor in the lens, so it will not autofocus with your D60. Their AF versions for Nikon will work with your camera's metering system for proper exposure, but you would have to focus manually.
SOURCE: Shutter speed and apertue not working for Nikon D60 Digital SLR
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: I am very new to using a slr digital camera. I
Yes. The expore time is long when you picture at night. Use the flash or TRIPOD! ;) The other way is to change ISO. It's better if you change is to 800, or 1600 or 3200 but be careful, there will be a lot of noise then! ;)
SOURCE: i need manual book for Nikon SLR D60, can someone
Here is a link for your user manual:
http://www.nikonusa.com/pdf/manuals/noprint/D60_ennoprint.pdf
Once opened, Save a copy to your computer for future use.
Thanks for using Fixya.
