I have a VS 5001R Mitsubishi TV that wont turn on. It sounds like its going to turn on when i hit the power button but then nothing happens. I tried holding the 2 input buttons for 5seconds... no code. There isnt a menu button. any advice??
This tv takes time for the picture to fade in so if you hold the power button to long it turns on but before the picture fades in it turns off so just tap the button and wait for the picture to fade in.
This chassis model line had issues with the vertical output IC shorting causing shut down.
It also had issues with intermittent solder connections in the Horizontal Circuit. I would not try to fix it your self unless you are very familiar with Projection circuitry and electronics background.
Hope this helps,
Skyassoc
