20 Most Recent
Mitsubishi VS-60607 TV Questions & Answers
Why wont my mitsubishi big screen tv turn on? the
Model number given indicates it should be a 2000 year model.
If so, it should have the self check feature; try to turn the set on and when the green light goes off: On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks,pause and 2 blinks (2,2 error code is most common one). It will repeat the error code several times.
Let me know what error code you find and I will tell you what it may mean.
if this told you something you did not know rate this solution as "very helpful" as I do this here for free.
You can post a comment on this page.
Regards, SD TECH
My mitsubishi 60 in turns
Well if your tv is older like the one in the pic it sounds like the bulb is overheating, you may want to vacuum the dust out of the back and make sure it isn't got block of air flow in the back and also make sure it isn't up against a heat source
Mitsubishi vs-60607 code 24
Here are the two top reasons that can cause the 60607 to throw a 23 or 24 code. Check these items then let me know what you find.
1. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop
if you may have more question , let me know Im here to help you.
thanks
Mitsubishi vs 60607 circuit board
this isn't a notorious problem. many problems can cause this. the instant on/off behavior just says there is one of many fuses blown in the television. you can't just replace the fuse, when it fails get a failure code find out what it means and repair the problem. I would recommend paying someone to do it if you don't want to trash your mits set.
to get the code you hold down the menu and input button for 5 seconds after the on/off sequence. it is a 2 digit code with a pause inbetween, example 2 pause 2 pause 2 pause etc. is a 2.2 code
Have a mitsubishi diamond and the blinking ligth wont stop so the tv wont turn on
ONLY 1 of 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wirescoming from the front keyboard of the set---remove the inspection plate andfollow the wires to the right--you can unplug both plugs(most have two and theyare marked with letters and different s so you cannot get them wrong)The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---You can call them and get a quote for repairing the receiver.Let me know what more information you need--I am here to help.SD TECH
