The display was always very difficult to see. display dim is set to maximum (100%) in settings. At the moment the display is totally invisible hope somebody knows the answer , not sending in for repair please Hans
SOURCE: panasonic sc-pt760
LOL if you just paid good honest hard earned cash for it i would certainly take it back. You might get a few freebies in the process. If you never broke it, Dont try and fix it because you will be held responsible for any damage they deem fit to blame you for.
SOURCE: Hot to make Philips HTS6100 region free?
Figured it out unlock for HTS6100, it's the same as for HTS8100
1. Turn on
2. Press Eject
3. Press 9, 9, 9, 9, 0
4. Swtich it to standby
5. Turn the player back on & it should now be region free.
SOURCE: Hi my soundbar tell worng region when i want to
sounds like you have one for the wrong reigon. cheek with the manual, if you have one. you may be able to fix so it will play them.
SOURCE: The unit display is too dim.
Bad news so please don't rate me on this. The display itself needs to be replaced and the part is nla (no longer available)
SOURCE: Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Testimonial: "Thank you..... I suspected that might be the case :( Just thought I'd ask if there was a way to reset it before schlepping it into the repair shop."
