SOURCE: maytag front load washer washes and doesn't spin, a lot of water
Clean your drain pump filter.
SOURCE: when i spin wash tub wigth my hand i can hear lots
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
SOURCE: A lot of water left under the washing machine. It
Is it aking a noise like a loud jet plane? If so it is a bad bearing and you can call around to get prices but I know it is an expensive repair.
