20 Most Recent Bosch 24 in. SGS43C02 Classixx Built-in Dishwasher Questions & Answers
Periodically will not pump out a end of cycle and dryer operates and dishes all cloudy
check that the drain pipe is not blocked or has a bend in it as this will stop water passing easily, remove and blow down pipe to make sure its clear. (wash out mouth afterwards) if this is fine then the pump must be weak or something is stopping its movement. if it is the pump you will need to remove it from washer and open the pump up by the 3 screws and remove the propeller and clean out the housing and pump parts, should be magnetic type and easy to fix. build up of food debris can limit the pump from moving.
12/13/2017 11:05:26 PM • Bosch 24 in.... • Answered on Dec 13, 2017
Last couple of days bottom rack of dishwasher not
the spinner arm itself may be blocked..............remove arm and check hold are clear.......... cheers
7/30/2017 4:49:50 PM • Bosch 24 in.... • Answered on Jul 30, 2017
What dose check water meeans
it means it cant feel if any water is entering the machine. either due to the water being turned off somewhere , the inlet hose not connected or the inlet flow sensor has failed
11/23/2014 3:32:51 PM • Bosch 24 in.... • Answered on Nov 23, 2014
When the wash is complete
Either the heater unit or the dryer fan is faulty.
Check that you have not been using the Eco wash cycles.
Also make sure you are using the detergent and rinse-aid recommended in the dishwasher manual.
5/25/2011 12:48:15 AM • Bosch 24 in.... • Answered on May 25, 2011
Springs on detergent compartment have come
It's fairly easy but you need to remove the front panel of the door first. To do this you will need a T20 T-Star screwdriver or screwdriver bit then follow these instructions:
1. Open the door and fold it down flat - there are 10 screws (T20) around the edges of the door
2. Undo and remove the 3 screws on each side - leave the 4 screws at the top!
3. Close the door
4. Grab the door at the bottom on both sides and pull gently towards you about 2-3 inches.
At this point you may find that 2 plastic clips fall out. Don't panic - it's not broken. They slide back on when the panel is removed.
5. When the bottom of the door is pulled away, pull it downwards and it will slide out from behind the control panel. The outer panel of the door should now be completely free.
You will now be able to see the back of the detergent compartment where the springs are located. Re-attach the springs, then re-fit the door following the instructions above in reverse order. If one or both of the clear plastic door clips have come off, reattach them to the brackets at the bottom of the door before re-fitting the panel. It's much easier this way!
T-Star bits are freely available - I've attached a picture of one.
If you get into any difficulty removing or refitting the door, please post back and I will assist you further.
10/21/2010 4:36:03 PM • Bosch 24 in.... • Answered on Oct 21, 2010
I have a Bosch SGS4452AU dishwasher purchased 7
100% fact. But people would not agree. Some times the washing machine left un attended, it will become a walking machine during spin cycle.
Contact the service provider and get appliance inspected. It could any thing!
5/27/2010 7:19:47 AM • Bosch 24 in.... • Answered on May 27, 2010
Hot water
Please help us ellaborate the issue so that we can assist you better.
Waiting for some more info.
Thanks
5/17/2010 5:53:16 PM • Bosch 24 in.... • Answered on May 17, 2010
Cycle interupted until pressure applied to door
problem on the safety switch
1)try to adjust the safety switch to contact properly with the door.
2)any screw is there on switch means loosen the screw &adjust to contact with door.
1/8/2010 10:52:44 AM • Bosch 24 in.... • Answered on Jan 08, 2010
How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
7/9/2008 8:37:16 PM • Bosch 24 in.... • Answered on Jul 09, 2008
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support 1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish... This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ... 9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone. 1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your ..https://www.youtube.com/watch?v=Xr4DBwACUW4
4/15/2024 10:37:04 PM • Bosch... • Answered on Apr 15, 2024
Water dripping out of last hole in Bosch upper spray arm getting dishes below wet
the unit could be un-level
3/22/2024 4:43:03 PM • Bosch... • Answered on Mar 22, 2024
Model shy56ao5uc/23. How can I turn off alarm?
YOU CAN ONLY LEARN TO ATTEND TO IT WHEN IT SOUNDS . THEY HAVE NO FEATURE TO TURN IT OFF OTHERWISE
3/4/2024 11:14:58 AM • Bosch... • Answered on Mar 04, 2024
2answers
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM • Bosch... • Answered on Jan 20, 2024
I have a Bosch SHE58C. What is making this noise?
This is the parts schematic that shows all the parts and where they are located. The noise is either something stuck in the pump or a dry bearing. https://www.searspartsdirect.com/model/25b4iqte9a-001794/bosch-she58c02uc-50-dishwasher-parts ..
1/18/2024 1:01:01 AM • Bosch... • Answered on Jan 18, 2024
3answers
Will a new Bosch dishwasher fit into the space of my 20-yr-old Bosch dishwasher?
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in. https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31 DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31 As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet. ..
1/3/2024 11:11:40 AM • Bosch... • Answered on Jan 03, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted. In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling. An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
E15 Bosch Dishwasher Error Code
8/27/2023 3:43:43 PM • Bosch... • Answered on Aug 27, 2023
Bosch dishwashers E 24 erro code.
8/15/2023 10:21:48 AM • Bosch... • Answered on Aug 15, 2023
My Bosch SMS6HCI01A makes a sound on closing door
8/15/2023 10:14:52 AM • Bosch... • Answered on Aug 15, 2023
Bosch SHU66C05UC/40 is not cleaning dishes and leaves film
It needs descaling. Try CLR in a wash
7/25/2023 4:52:38 AM • Bosch... • Answered on Jul 25, 2023
Bosch 24 in. SGS43C02 Classixx Built-in Dishwasher Logo
Popular Tags
18 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
cycle interupted until pressure applied
  • Dishwashers
