Nokia 3230 Cellular Phone Logo
Posted on Nov 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove write protection in mini sd card? when process in running
  • 1 more comment
  • Anonymous Feb 27, 2008
    i have tried by moving lock to both side but still windows is saying that it is write protected use another card
  • Anonymous Jun 04, 2008
    how remove the write protection in microsd memory card
  • Anonymous Sep 07, 2008
    i had the same problem with my sd card. i tried putting tape over the little lock switch so it didn't move when you inserted it into the card reader and it worked right away!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5408
Points
9
I hope this helps - I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!!!!!!!!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now.....don't know why this has to be done, but it works!!!!!!!!!
  • psziva
    psziva Apr 05, 2013
    i know how to unlok adapter tell me how need to unlock microCD card witch one not let put in or delet anything and not let format
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Dec 11, 2007
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
30489
Points
201
There is a mini switch that goes up in down on the left or right side. Slide it on the opposite direction to remove write protection. ü
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Aug 12, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
8
Helped
5664
Points
10
Dear Guests,
the mini switch provided on Adapter do not remain in its position while inserting the card in card reader due to its poor workmanship. hence you can try by using a n opaque material such as insulation tape to cover the mini switch on adapter so that it remains in the "Open" position while inserting it in card reader.Do take care that it will not cover the metalic contacts. The "Open" position is towards the contacts, so keep the switch accordingly. This may help, It has solved my problem.
Anonymous
Level 1:
  • Posted on Feb 07, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5408
Points
1: Make sure the switch on the side is in the "off" position.
2: Use one wrap of black electrical tape, or (preferably) two wraps of cellophane tape around the entire card (both sides). This will cover the notches, which are a kind of code that the card slot will recognize. Make sure you do not cover the gold contacts, or use so much tape that the card will no longer fit into the slot.
IMO the problem is not the card, but cheap card readers. This is just a workaround.
Anonymous
Level 1:
  • Posted on Oct 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5542
Points
Yup worked great. Just like hudsenplutzsaid. I did use clear (see through) tape and it still worked fine. Thanks for the help.
Anonymous
Level 1:
  • Posted on Jul 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5408
Points
Thanks works great with my mini sd. nice tip.
psziva
Level 1:
New Friend:
  • Posted on Apr 05, 2013
psziva
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5408
Points
I know how to unlock that stupid adapter rather tell how to unlock microCD witch one even not lett formate
  • psziva
    psziva Aug 13, 2014
    how need to unlock this microsd in left not that in right?
Anonymous
Level 1:
New Friend:
  • Posted on Jun 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5408
Points
How it can be removed by setting through conputer, if anybody hav'nt card adapter.means just have a card and card reader as a sort?????
Anonymous
Level 1:
New Friend:
  • Posted on Dec 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5408
Points
Wat whole gap do u cover?
A
Anonymous
Ok..so my reader is kinda different ,,,,its like this all in one card reader thinggy,,,, and there isn't and switch...pls help me.... T_T
A
Anonymous
Thanks this helped alot
A
Anonymous
I tried Soultion # 2 and it worked right away on my Kingston SD Mini card
A
Anonymous
Hudsons tip does not workk i tried it with my SD card I NEED HELP
A
Anonymous
Hudsen tip works!!
I didn´t believe at first, but tried anyway.
Unbelievable, it worked well!
A
Anonymous
Thats crazy, i jus did what hudsen explained and it worked like a charm thanks dude...how did u manage to figure it out tho?!
A
Anonymous
Nothing happened.Mine is Kingston MiniSD 1gb made in Taiwan, also face the problem.Only can be deleted inside the phone.I am using xphone IIm.
Try to use another adapter, or just delete your file while inside your phone.
2 Related Answers
chamboard
B.Th. Pluijm
  • 558 Answers
  • Posted on Oct 22, 2009
SOURCE: My mini SD memory card is write protected how i
on the side from the sd card are litel handel move this to write (compleet acces) the card try it in the pc or card reader/writer if you have acces then it wil work then take out the sd card adapter and put mini sd card into the phone
Anonymous
  • Posted on Dec 21, 2009
SOURCE: how i remove write protection in my mini sd memory card
Just go in these page there are a solution...
http://www.instructables.com/id/S27LXZRF7DWO18T/
How can i format write protected sd card...
You must first remove the write protection. Here is a link to a wiki article explaining the write protect removal process and how to format using Windows or MAC.
How to Remove Write Protection on an SD Card
Oct 22, 2015 • Cameras
How do i remove a write-protection from a mini sd card?
Most mini SD card have a tiny slide switch on the side of the card. Move the slide switch from the read only (writr protect) to the write position.
I inserted kinston 4gb card in my digital camera , while in the unlocked position of switch.But camera shows "memory card error" "card locked"
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
  • Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protection_from_a_mini_SD_card#ixzz1Fvsnj1XE
    How do i turn off the write protection on my mini SD card?
    On the Mini SD adapter, there is a lock tap you push down usually when you put your mini SD card in to it, then into the USB adapter. To turn off the write protection on your mini SD, simply do not lock your mini SD in its adapter.
    If that doesn't work, the write protection sensor in the device reader is not reading the card's lock switch properly. First, try moving the lock switch on the card slightly towards the lock position - this worked for me. Another trick is to put a piece of tape over the lock switch area on the card. It seems the fail-safe position is write protected, unless the switch is closed by the tab on the card in the 'unlocked' position, signaling a writable card.
    If these simple tricks don't work, the 'unlocked' sensor in the device reader may not be working; it's likely to be a mechanical switch that my have failed. Some have claimed success performing micro surgery to permanently short the switch in the closed position, essentially removing the write protection. This would require more skills that the average person has. Proceed at your own risk of damaging the device.
    2helpful
    I got the message "Your Disk is Write Protected" when i go to format. How i format my Transcend disk. Please help me. Thanks.
    Removing the write protection depends on the source of the problem.
    Broadly speaking, it can be any of the following scenarios
    1. There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
    2. There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
    3. The mini sd card has some error: Go for a low level formatting.
    4. The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
    There is an easy way to solve this problem: Simply put the yellow lock in the middle of its slider. No sticky tape required, as shown below. But if your still having the same problem i suggest you try the sticky tape.
    problem is only that small moveable yellow lock switch is not making, just put sellotape over it maybe two layers needed to make switch.
    == Answer == Even though what is written below may work, the problem is probably that on the card reader (if you have one) there is a small switch that has lock written on the side. If this is pushed down, the drive is write protected, push it in the opposite direction and it may fix your problem I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
    Your card should work fine now... don't know why this has to be done, but it works! Additional info:
    Reason #1,
    the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
    Reason #2
    If the above fails, it is likely your SD card reader/writer's fault. But don't discard it or buy a new one yet. Allow me to explain the mechanical design of the SD card lock mechanism. So that you may choose to repair it if you want to. You will need a small paper clip and screw-driver to open your card reader. (Don't proceed if your card reader is still under warranty, please return/exchange with manufacturer) There is a mechanical switch very much like a micro push button (I wish I could show you the picture/drawing). Anyway, depending on the position of the lock switch. You either push or release this micro push button inside the SD card reader.
    Due to mechanical wear and tear, or some forceful insertion of the SD card, the micro push button is in its "open" circuit position, i.e. write-protected. In order to make the SD card reader writable, we will need to "close" the circuit. (Note: this is an irreversible process as I will be telling you how to remove the write-protection feature of your SD card reader. Once you do this, you would be unable to use the SD card lock switch to lock your data. So, just be careful not to accidentally delete your data)
    To proceed, you need to remove the main circuit board from the SD card reader/writer enclosure. The location of the micro push button switch is the same location as the unlock position of the SD card when inserted in the SD card reader/writer. From the BACK of the exposed SD card reader, insert the unfolded paper clip (same way when you try to poke something like a device reset button) except, that it has to be long enough to allow the micro switch to touch together for contact. Then insert the SD card. Once the contact is "closed", your SD card reader/writer can write again. I understand that without a drawing, this may not be very helpful. Please provide suggestions or better explanation if you can. Thanks.
    Or, just tape the lock switch to unlocked. This also works for SD cards in normal size. back up all the files u have on ur card then follow these steps
    1. Go to Control Panel
    2. Go to Administrative tools
    3. Go to Computer management
    4. From the tree menu on the left select Disk Management
    5. Now on the right side you will have a list of all storage devices connected to your computer. Select the one that is your mini SD card. BE CAREFUL WHEN CHOOSING THIS BECAUSE YOU COULD FORMAT YOUR HARDDRIVE. Double check the name in My Computer
    6. Right click on the SD card and select format. A new window will pop up showing format options. Select FAT32 from the file system drop down and check the quick format option and then click on OK
    7. Enjoy your mini SD card without that annoying write protection
    2helpful
    How to remove write-protection
    Dear Friend,
    • Change the Usb Port(Recommend you to Use Backside Port)
    • Change the Cable
    • Restart PC
    • Still have Problem Change Card Reader..
    Hope this Helped you..Thanks for Contacting FixYa...........
    1helpful
    How to remove write protection from sd memory card
    On the Mini SD adapter, there is a small lock tap button,you push down usually when you put your mini SD card in to it, then into the USB adapter. To turn off the write protection on your mini SD, simply do not lock your mini SD in its adapter.
    MicroSD atchment write protect
    The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
    Hope it helps: let me know how you go!
    Mar 07, 2010 • Cameras
    My mini SD memory card is write protected how i remove?
    1helpful
    How i remove write protection in my mini sd memory card
    Top Nokia Cell Phones Experts
    Kolbrun...
    Muhammad Irshad...
    Muhammad Irshad...
