20 Most Recent PNY 2GB microSD Memory Card Questions & Answers
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
PNY 2GB microSD... | Answered on Aug 13, 2019
bad memory card happens alot buy a new one!
PNY 2GB microSD... | Answered on Jan 22, 2018
GT Recovery for Windows Download: www.gtrecovery.net
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices.
It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
PNY 2GB microSD... | Answered on Jan 11, 2018
It could be that the devices into which you inserted the SD card are not designed to accept SD cards of that type.
There are 3 SD card types: SD, SDHC and SDXC. If the SD card size is 4GB to 32GB, the type is SDHC, and if the card is larger than 32GB, it is an SDXC type.
Newer devices will accept SDHC and SDXC cards, but older devices may not be able to read those SD card types. You should be able to check the specifications of the devices you are using by looking on the device manufacturer's web site.
PNY 2GB microSD... | Answered on Sep 28, 2017
Depends on the size of each file ( picture). If your shooting a large formate then it could ( that's all you can get on it.
PNY 2GB microSD... | Answered on Jun 02, 2017
Files must have the correct extension. i.e. .wav or .mp3 or whatever the music player requires. You may need to convert the sound file to a different type for the device to see it. It may show in one device and not another for this reason
PNY 2GB microSD... | Answered on Apr 21, 2017
You can go direct to the following link
HTTP://nationalgeographic.pny.com/
BUT only allows you one choice:
An Elephant Call.
Plus, you have to download a bunch of stuff that you probably don't want on your phone.
As nornal, it's a rip-off AD by PNY
PNY 2GB microSD... | Answered on Mar 21, 2017
I would suggest you "NOT" to copy anymore files on your SD Card to prevent data loss or data corruption. Stop using it immediately.
Download an undelete program such as Undelete Plus. I think its a free download. and run the
program to recover your pictures. If you attempt to continue to use your SD Card you are at
higher risk of loosing your data.
PNY 2GB microSD... | Answered on Nov 15, 2016
Hello Afridi,
First scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
http://www.avira.com/en/free-download-avira-antivir-personal?
Download the .exe file from the link.
Install the software in your computer.Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
Then try the Data Recovery Software available in market to recover the files. Install the demo software of the data recovery software( Recover Data for FAT and NTFS) from their particular website. Then scan the memory card using the Data Recovery Software. If the demo software displays all your data you need then purchase their full version software to save your valuable data. Because in demo software you are not able to save the data. Please try the data recovery software for FAT and NTFS partition.
Please download the demo software from the link provided below :
http://www.recoverdatatools.com/download-windows-data-recovery.html
Download the software from the above link and install it. There are two recovery modes available in the software Normal and Exhaustive mode. If the software did not find any data in Normal mode than try the Exhaustive mode available in step 2B in the software. If you are installing the software in Windows Vista or Windows 7 then run the software as administrator after installing it.
PNY 2GB microSD... | Answered on Jul 14, 2016
There is a utility that is built into windows its called DISKPART
Make sure you select the USB drive not your OS/Data drives
Try this link http://knowledge.seagate.com/articles/en_US/FAQ/005929en?language=en_US
PNY 2GB microSD... | Answered on Oct 20, 2015
Hi
You need SD Card adapter in order to use it in a desktop or you can get a MicroSD USB card reader
Look at link attached 2GB Micro SD Card with SD Adapter Giveaway Phone Memory Card Micro SD Card Reader Adaptor USB
You need a SD card adapter to insert a MicroSD card and be able to use it
Put them into "my sounds" folder or into a music folder and use them from there. The ring tones are wright-protected.
PNY 2GB microSD... | Answered on Aug 24, 2015
I've used Recuva (free download). Do a thorough deep scan and save to another drive. Very simple to use as long as you have not reused same physical space on card.
http://www.piriform.com/recuva
PNY 2GB microSD... | Answered on Aug 18, 2015
How to recover data from memory Card:
Memory Stick Recovery - Recover lost memory stick data Have you deleted your files (music, videos, photos or documents) from your Memory Stick wrong? And you are finding Memory Stick Recovery software to recover the deleted files? If yes, keep reading. This tips shows you how to recover deleted/formatted files from your Memory USB Stick.
How to recover data from memory stick:
1. Download Finalseeker Card Data Recovery software and install it in your windows..
Free Download Finalseeker Card Data Recovery software 2. tart Finalseeker Card Data Recovery software and insert memory stick to computer.
3. Select one or more file types you want to recover from memory stick. If the file type you want to recover isn't photo, music, or video, you can select all option. The all option will retrieve all file from you memory stick.
4. Select a USB Drive to scan and retrieve the lost data. Tips: You can find the USB drive at Removable Media1 category.
5. Preview to choose the file you want. If the file cannot be preview, you also can recognize it by the file size and file name suffix.
6. Click the Recover button to recover the lost file to another partition or drive. Tips if the file has been overwritten by new data, the recovered file may not be able to be open correctly. If this happen to you, the best way is to try to use other memory card data recovery software.
PNY 2GB microSD... | Answered on Oct 07, 2014
simply select it in the "my computer" section, right click it and select format
PNY 2GB microSD... | Answered on Aug 13, 2014
You can recover photos after memory card from with asoftech photo recovery. I used the program before, you can download trial for free.
http://www.asoftech.com/products.html
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
PNY 2GB microSD... | Answered on Jun 30, 2014
Okay, heres the bad news, there's a good chance that you will not get all of your pictures back. The good news is that most formatting only allocates space as empty, it does not actually overwrite it, so the picture data may still be retrievable.
I have used a sweet little freeware program called Restoration, which can try to recover deleted files from hard drives, jump drives, flash cards, ect, and have had great success with it. Heres a link to the download page:
http://www.snapfiles.com/get/restoration.HTML
Like I said, it probably wont' restore all the pictures, but I'll bet long odds that it can get most of them back. Good Luck!
PNY 2GB microSD... | Answered on Apr 17, 2014
It seems that your mobile memory card corrupted or damaged then it cannot be read by your computer. You can try 4Card Recoevry to restore your data if you want to. It can recover pictures, films, e-mails and other files.
First, download 4Card Recovery on the internet and install it on your computer.
Next, run it and select all to recover so that you will not miss anything.
Then, click the ' next' button to scan it, and you are supposed to wait for about ten minutes here. So to be relax, and do not get into panic if you find it is keeping scanning.
Finally, store your recovered files on other part.
You can downlaod it for free. Have a try.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
PNY 2GB microSD... | Answered on Apr 05, 2014
PNY 2GB microSD Memory Card Logo
Popular Tags
414 questions posted
Top PNY Electronics - Others Experts
Marvin
Marvin
Ekse
Joe Negus
Joe Negus
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Electronics - Others
Most Popular Question
memory card micro sd
  • Electronics - Others
