20 Most Recent
Nokia 3230 Cellular Phone Questions & Answers
Regarding video clips
The vidios recorded in mobile phones are of 3gp format. This is different format then using windows player. You have to install Nokia Multi Midia Convertor from PC suite cd into your PC. There are more players for playing 3gp format named MMConvertor Pro. You can easily download them from free webs or can mail me
[email protected]
I have a mobile witch have ben stold som days
along with the IMEI number please register a complaint to police that i had lost my phone..before doing this,contact the customer care of the mobile operator and tell them to block the usage of the sim..u can call from an alternate number..
Help please! My nokia 3230 failed to start up.
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
How to remove write protection in mini sd card?
I hope this helps - I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!!!!!!!!
Make sure the SD card lock is 'off' and then use thin, opaque sticky
tape (ie non see-through; eg insulation tape) to cover the whole gap
but keep clear of the metal contacts at the back.
Your card should work fine now.....don't know why this has to be done, but it works!!!!!!!!!
Unable to connect to the net with opera mini on my cherry mobile w1
In all honesty Opera browser is moderately outdated. My personal suggestion to you is to deinstall Opera and replace it with Google chrome. If this does not correct your problem, please ensure your device is properly connected to the internet. (I.e WiFi, or cellular data)
Thanks,
Dish Guy
Unable to connect to the net with opera mini on my Nokia 3230
to connect to the internet & to send & receive mms messages you
must activate the GPRS first from your network provider ...The best
thing you can do is to contact the customer care of your network
provider and ask for the activation of GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you will receive the gprs settings(profile) also ... make sure of
the charges with them there will be many plans & then get activated
after this you will able to connect to internet ....
if
the customer people tell you that your handset is not compatible then
you must tell to give the manual settings(includes ip address,APN,etc)
so that you can only create the profile and input the information given
by the customer care people...
any further doubts reply me
i am always here to assist you ..
thank you
bye...
Unlock key
first of all tel me your phones imei no. then i will tel you the license key
11/13/2013 11:09:37 AM •
Nokia 3230...
Answered
on Nov 13, 2013
My nokia 3230 is dead
if u really went to any nokia support center who's specified for fixin' the nokia phones they'll tell u that the logic circuit is down i had tha same problem and the phone center (RA'A) in egypt have fixed my phone for only 300 EP = 52.99 Dollars so go and check it out
