SOURCE: instruction manual for celebrity pride 3 wheel mobility scooter
I can send you the manual (PDF) if you send me your email address. My address is (D*H*u*d*s*o*n at GMail dot com), you need to take the stars out and put the @ symbol in and the .com to make it usable.
SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
SOURCE: PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
SOURCE: pride mobility scooter wont move
hi, that noise could be a relay clicking off inside the motor controller because the brake on the motor has failed to release,
It quite a common problem and the only way to be 100% sure is try a replacement brake unit.
Regards
GeWiz.
