20 Most Recent Electric Mobility Merits Electric Wheelchair Scooter Battery Charger Questions & Answers
Make sure the connections are on correctly!
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Electric... | Answered on Jul 03, 2016
there should be two sets of cables, 1 set per battery, do not put one cable on one battery and one on another. Black is - and Red is +. the each cable plugs into its connector into the scooter system.
http://www.meritsusa.com/UploadFile/common/file/20160125/20160125064145_5387.pdf
Electric... | Answered on May 01, 2016
Going and Slowing is usually a problem with the throttle pot. They are often easy to fix yourself with a bit of WD40 once you have found out where the throttle pot is on your machine. Sometimes they have to be replaced, but fortunately the part is quite cheap. You didn't say what brand your scooter is, but Pride scooters are known for throttle pot problems.
Electric... | Answered on Sep 18, 2014
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Electric... | Answered on Aug 10, 2012
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Electric... | Answered on Apr 27, 2011
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
Electric... | Answered on Mar 25, 2019
spares
http://www.monarchmobility.com/servicing-department/
no idea on user guide, sorry but it looks like they do not have an online version, you could ask the above people if they have a copy. or were you could get one.
Electric... | Answered on Jul 04, 2018
Firam 250mg Buy Firam 250mg Online, uses, price, dosage, cost
Electric... | Answered on Jun 04, 2018
Request the wiring diagram directly from Electric Mobility.
Electric... | Answered on Mar 10, 2018
Electric Mobility Merits Electric Wheelchair Scooter Battery Charger Logo
18 questions posted
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Dan Kostella
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Electric Mobility Health & Beauty
Most Popular Question
electric scooter hesitates goes
  • Health & Beauty
