20 Most Recent
Pride Go-Go Ultra X 3-Wheel Travel Scooter Questions & Answers
Click and clunk when moving from right rear wheel Pride Elite +
This can be caused by two things usually. One cause is the bolt holding wheel to the axle is a little loose so check to make sure it is very tight on the axle. The second click comes from flat-free tires. The tires have an adhesive applied at the factory and if you hit a bump, or if there's not enough to hold the tire tight to the rim, the tire will make a grinding click noise when it rolls and passes over this area. Pneumatic tires properly inflated don't make this noise since the air pressure keeps the tire fixed to the rim at the bead; flat free tires lack this pressure. Simply lubricate the area around the tire where it meets the rim on inside and outside, and drive it...noise should dissipate.
Why does it stop then goes after charging?
Hi first thing to do is get the batteries load tested U can buy a load tester of E/BAY APROX cost $35 ,..this will give U an accurate reading on there condition ,...cheers
HOW DOES BATTERY COME OFF TO CHARGE ON GO GO SCOOTER
The battery box is secured to the scooter base with poly lock Velcro. By pulling straight up on the battery box handle, the battery box can be removed for charging or transport. When reinstalling make sure to align the pins and block on the battery box bottom with the receptacle on the base. Hope this helps.
Wont move 5 beeps and freewheel lever is properly engaged
hi Cornelius,
Check the micro switch located on the brake, if that working okay as sometimes they stick... if the controller can't see the brake resistance it will bleep five times...
then check the connections from the axle to the frame , four connectors , tow for the motor and two for the brake.
Feel free to call me if you're located in the UK
Regards
Rob..
HOW DO I RECTIFY THE FAULT IN MY SCOOTER?
hi Laurie, the five bleeps is related to the brake , you need to check the connections between the axle and the frame and the connection to the brake...
Regarding a circuit diagram... Pride would never supply such a thing, it's propriety information.
Regards
Rob
How to remove seat & battery
Hi' I have a pride gogo scooter, to take the seat off just take the pin out and then push the swivel lever up and then just jiggle it and it lifts off. To remove the battery remove the canopy thats situated under the seat,then undo the strap and disconect the the front battery plug(harness) and the do the same with the rear one then your battery will lift out.
